Built in player issues.
Postby Buck0wens » Thu Nov 13, 2008 9:11 pm
I just upgraded to v3.5. I've never used the web player before so I'm not sure if this is an upgrade issue. The player works fine after all the songs are loaded but as soon as I add a new song, the playlist re-starts the from the beginning. I'm not sure if this is a bug or a configuration issue on my part but I figured you should know about it. Thanks in advance for any info and thank you for this wonderful program :).
Patrick
Buck0wens
Postby mixmaster » Thu Nov 13, 2008 9:37 pm
That's how it works, there is no on-the-fly editing of playlists.
________
mixmaster
