Tomcat7 - Subsonic 4.9 beta 2 help
Postby HerrNilsson » Thu Dec 12, 2013 2:25 pm
Installing a new machine with Tomcat 7.0.26, Subosnic 4.9 Beta 2 on an Ubuntu Server 12.04.3 LTS with java version "1.7.0_25".
OpenJDK Runtime Environment (IcedTea 2.3.10) (7u25-2.3.10-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 23.7-b01, mixed mode)
Most of it works, but when i click "Change administrator password" after the login i get the error message below
Exception    org.apache.jasper.JasperException
Message    /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
Java version    Oracle Corporation 1.7.0_25
Operating system    Linux 3.8.0-29-generic
Server    Apache Tomcat/7.0.26
Memory    Used 32 of 45 MB
Stack trace    org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp (line: 122, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}] at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42) at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408) at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:199) at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1218) at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:870) at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428) at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:889) at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428) at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2434) at org.apache.jasper.compiler.Node$Root.accept(Node.java:475) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376) at org.apache.jasper.compiler.Validator.validateExDirectives(Validator.java:1790) at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:217) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:373) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:646) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:684) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:471) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:402) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:329) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501) at javax.servlet.http.HttpServlet.service(HttpServlet.java:621) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579) at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1805) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:724)
Anyone know what to do? Thanks!
HerrNilsson
Re: Tomcat7 - Subsonic 4.9 beta 2 help
Postby daneren2005 » Thu Dec 12, 2013 3:58 pm
Personally, I would post about this issue with Tomcat on the beta thread. I'm not sure if Sindre looks here, but I'm pretty sure he is checking that one for anything that gets broken.
