Media scanning stopped working?
Postby SparkyRih » Sat Dec 21, 2013 8:19 pm
So like I wrote in the subject, media scanning has stopped working... My media library is not updated automatically nor manually...
I'm running version 4.8 on Ubuntu 12.04 and didn't make any modifications for a long time, so it basically suddenly stopped working...
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Re: Media scanning stopped working?
Postby alphawave7 » Sun Dec 22, 2013 5:21 pm
What flavor running (Mad,Cab, stock?) and are there any clues in log?
Postby SparkyRih » Wed Dec 25, 2013 12:10 pm
Just stock, and I can't find anything odd in the log:
[12/24/13 9:00:17 PM CET] INFO MediaScannerService Completed media library scan.
[12/24/13 9:00:21 PM CET] INFO PlaylistService Starting playlist import.
[12/24/13 9:00:21 PM CET] INFO PlaylistService Completed playlist import.
[12/24/13 9:00:21 PM CET] INFO PlaylistService Starting playlist statistics update.
[12/24/13 9:00:21 PM CET] INFO PlaylistService Completed playlist statistics update.
[12/25/13 1:01:44 PM CET] INFO PlayerDao Created player 189.
[12/25/13 1:01:44 PM CET] INFO PlayerDao Created player 190.
[12/25/13 1:01:44 PM CET] INFO PlayerDao Created player 191.
[12/25/13 1:01:44 PM CET] INFO PlayerDao Created player 192.
[12/25/13 1:02:01 PM CET] INFO MediaScannerService Starting to scan media library.
[12/25/13 1:02:02 PM CET] INFO MediaScannerService Scanned media library with 250 entries.
[12/25/13 1:02:02 PM CET] INFO MediaScannerService Scanned media library with 500 entries.
[12/25/13 1:02:03 PM CET] INFO MediaScannerService Scanned media library with 750 entries.
[12/25/13 1:02:03 PM CET] INFO MediaScannerService Scanned media library with 1000 entries.
[12/25/13 1:02:03 PM CET] INFO MediaScannerService Scanned media library with 1250 entries.
[12/25/13 1:02:04 PM CET] INFO MediaScannerService Scanned media library with 1500 entries.
[12/25/13 1:02:04 PM CET] INFO MediaScannerService Scanned media library with 1750 entries.
[12/25/13 1:02:04 PM CET] INFO MediaScannerService Scanned media library with 2000 entries.
[12/25/13 1:02:05 PM CET] INFO MediaScannerService Scanned media library with 2250 entries.
[12/25/13 1:02:06 PM CET] INFO MediaScannerService Scanned media library with 2500 entries.
[12/25/13 1:02:06 PM CET] INFO MediaScannerService Scanned media library with 2750 entries.
[12/25/13 1:02:07 PM CET] INFO MediaScannerService Scanned media library with 3000 entries.
[12/25/13 1:02:07 PM CET] INFO MediaScannerService Scanned media library with 3250 entries.
[12/25/13 1:02:07 PM CET] INFO MediaScannerService Scanned media library with 3500 entries.
[12/25/13 1:02:08 PM CET] INFO MediaScannerService Scanned media library with 3750 entries.
[12/25/13 1:02:08 PM CET] INFO MediaScannerService Scanned media library with 4000 entries.
[12/25/13 1:02:08 PM CET] INFO MediaScannerService Scanned media library with 4250 entries.
[12/25/13 1:02:09 PM CET] INFO MediaScannerService Scanned media library with 4500 entries.
[12/25/13 1:02:09 PM CET] INFO MediaScannerService Scanned media library with 4750 entries.
[12/25/13 1:02:09 PM CET] INFO MediaScannerService Scanned media library with 5000 entries.
[12/25/13 1:02:10 PM CET] INFO MediaScannerService Scanned media library with 5250 entries.
[12/25/13 1:02:10 PM CET] INFO MediaScannerService Scanned media library with 5500 entries.
[12/25/13 1:02:11 PM CET] INFO MediaScannerService Scanned media library with 5750 entries.
[12/25/13 1:02:11 PM CET] INFO MediaScannerService Scanned media library with 6000 entries.
[12/25/13 1:02:12 PM CET] INFO MediaScannerService Scanned media library with 6250 entries.
[12/25/13 1:02:12 PM CET] INFO MediaScannerService Scanned media library with 6500 entries.
[12/25/13 1:02:13 PM CET] INFO MediaScannerService Scanned media library with 6750 entries.
[12/25/13 1:02:14 PM CET] INFO MediaScannerService Scanned media library with 6987 entries.
[12/25/13 1:02:14 PM CET] INFO MediaScannerService Marking non-present files.
[12/25/13 1:02:14 PM CET] INFO MediaScannerService Marking non-present artists.
[12/25/13 1:02:14 PM CET] INFO MediaScannerService Marking non-present albums.
[12/25/13 1:02:14 PM CET] INFO MediaScannerService Completed media library scan.
[12/25/13 1:02:14 PM CET] INFO PlaylistService Starting playlist import.
[12/25/13 1:02:14 PM CET] INFO PlaylistService Completed playlist import.
[12/25/13 1:02:14 PM CET] INFO PlaylistService Starting playlist statistics update.
[12/25/13 1:02:14 PM CET] INFO PlaylistService Completed playlist statistics update.
[12/25/13 1:02:59 PM CET] INFO PlayerDao Created player 193.
[12/25/13 1:03:00 PM CET] INFO PlayerDao Created player 194.
[12/25/13 1:03:01 PM CET] INFO PlayerDao Created player 195.
[12/25/13 1:07:18 PM CET] INFO PlayerDao Created player 196.
Edit: It appears that it only happens to one folder, but even if I CHMOD it 777 it won't get scanned...
SparkyRih
Postby priley2327 » Thu Jan 16, 2014 3:58 pm
Mine and a friends is doing the exact same thing. the nightly scan and manual scan will not work. the only way i can get it to update is remove the media folder, clean the database, and re add the media folder and do a scan then i will have all the newest media.
Using debian 7.3
i even wiped out debian and completely re did the entire machine to no success.
Version 4.9.beta4 (build 3810) – January 4, 2014
Server jetty-6.1.x, java 1.6.0_27, Linux (112.9 MB / 404.7 MB)
priley2327
Postby woodensoul2k » Thu Jan 16, 2014 4:33 pm
priley2327 wrote:Mine and a friends is doing the exact same thing. the nightly scan and manual scan will not work. the only way i can get it to update is remove the media folder, clean the database, and re add the media folder and do a scan then i will have all the newest media.
Using debian 7.2
I am the one he mentioned above. I just wanted to add I am actually using Debian 7.3 and I am using Oracle Java 1.7.0_45-b18 and sharing with smb/cifs shares. Just a small note, the scanning was not working in 4.8 either. Any help on this would be greatly appreciated. Thanks.
woodensoul2k
