Can't Connect
Can't Connect
Postby gateets » Thu Dec 26, 2013 11:10 pm
Can't connect to my subsonic server ( http://gateets.subsonic.org ) but I can connect to the demo server. I have checked, and re-checked, port forwarding, and have confirmed that port 8080 is open. If I try to open Subsonic in the browser I get Error 503. I managed to get to the login page via a link in another poster's message, but couldn't login or reset my password (also, 'admin/admin' username/password combo wouldn't work). I have tried accessing page by typing in IP:port (both public and private). I have just done a clean install of Windows 7, new Subsonic installation, and my Network Gateway was just replaced. Any ideas?
gateets
Re: Can't Connect
Postby ebrammer252 » Fri Dec 27, 2013 6:01 pm
I'm having the same issue with my personal server as well. I can access it locally on the server, but from any other machine it's not visible.
ebrammer252
Re: Can't Connect
Postby alphawave7 » Sat Dec 28, 2013 1:17 am
New Windows installations with failed LAN/WAN connections is usually due to firewalls. Also, always test your WAN accessibility using canyouseeme.org, as WAN access will only work if you pass that port test.
Re: Can't Connect
Postby gateets » Sun Dec 29, 2013 10:56 pm
Disabled both firewalls (Windows & Comodo) and checked with canyouseeme.org (port 8080 is open); still not working
gateets
Re: Can't Connect
Postby alphawave7 » Sun Dec 29, 2013 11:09 pm
Your old url is failing on port 8088, but since you say it's a new install, I assume you've redone the port and forwarding. Do you get nothing on the server at 127.0.0.1:8080?
Re: Can't Connect
Postby gateets » Wed Jan 01, 2014 6:29 am
Yes, I reconfigured the router port forwarding; no, that IP doesn't work
gateets
