subsonic doesn't work with a second admin user account
Postby luciomagano » Mon Dec 30, 2013 5:47 am
Problem Description:
Due to some running slow issues I've created an nº 2 admin user account to discover what is the cause of the issue on my OS Mavericks. Everything was fine and it inherited all apps from the admin account nº1. First time I opened subsonic on account nº2 it worked well - playback and everything else was ok - although I got an error message when checking out subsonic control panel: "java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Subsonic/jetty/3434". I restarted the system some time later and couldn't access subsonic webpage on account nº2 anymore. The webpage didn't load properly and the message on the browser was: "... could not connect to localhost:4040.."
Troubleshooting Steps: I installed subsonic logging on account nº2. Installation was fine. The control panel informed that port 4040 was already in use, I changed it to port 4041 but when I tried to open the webpage I got this:
"HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://"
Playback Application and version: Firefox 26.0
Subsonic Version: 4.8 (build 3434) – April 17, 2013
Server Version: jetty-6.1.x, java 1.6.0_65, Mac OS X (102.3 MB / 147.9 MB)
Hardware Platform: Mac OS 10.9.1
Java Memory Limit: couldn't locate
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines:
[12/30/13 2:44:44 AM GMT-03:00] INFO MediaScannerService Scanned media library with 103750 entries.
[12/30/13 2:44:44 AM GMT-03:00] INFO MediaScannerService Scanned media library with 104000 entries.
[12/30/13 2:44:44 AM GMT-03:00] INFO MediaScannerService Scanned media library with 104171 entries.
[12/30/13 2:44:44 AM GMT-03:00] INFO MediaScannerService Marking non-present files.
[12/30/13 2:44:48 AM GMT-03:00] INFO MediaScannerService Marking non-present artists.
[12/30/13 2:44:48 AM GMT-03:00] INFO MediaScannerService Marking non-present albums.
[12/30/13 2:44:48 AM GMT-03:00] INFO MediaScannerService Completed media library scan.
[12/30/13 2:44:49 AM GMT-03:00] INFO PlaylistService Starting playlist import.
[12/30/13 2:44:49 AM GMT-03:00] INFO PlaylistService Completed playlist import.
[12/30/13 2:44:49 AM GMT-03:00] INFO PlaylistService Starting playlist statistics update.
[12/30/13 2:44:49 AM GMT-03:00] INFO PlaylistService Completed playlist statistics update.
luciomagano
