No Connetction to the Network
Postby legi » Mon Dec 30, 2013 1:51 pm
Hi
Read many Forum threads but nothing helps.
I have a Fritzbox as router. I tried all with manual and automatic connections various Ports. Various error messages from "adress is registered but time out" to "route to host ..." and "error 404"
Can anyone give me easy instructions?
What is the protocol UDP or TCP to give the Port free?
is it right to give in the "from Port" and in the "to Port" (my PC) Box the same Portnumber?
now I have in the Subsonic Panel the Port 4040
thanks for any hint
Peter
legi
Re: No Connetction to the Network
Postby GJ51 » Mon Dec 30, 2013 5:31 pm
Postby alphawave7 » Mon Dec 30, 2013 5:34 pm
Only TCP is required, but I've always chosen both UDP/TCP, as it is often a default entry. In and Out are required, ensure you're applying to your server's FIXED LAN IP. Cheers!
