Subsonic on ReadyNAS fails to transcode
Postby Karel » Fri Jan 03, 2014 1:52 pm
Problem Description: I have installed the latest version of Subsonic on ReadyNAS 102, by using the Debian installer package. It runs fine, but only if I switch off the transcoding. If I set transcoding to "on", then it doesn't work. iSub reports that the problem occurs due to a transcoding error.
Troubleshooting Steps: switching transcoding on/off
Playback Application and version: iSub for iPad, Subsonic for Adroid and webplayer in firefox windows 7.
Subsonic Version: 4.9.beta3 (build 3772) – December 14, 2013 (i have tried older versions, 4.4 and 4.8, but the same problem occurs)
Server Version: jetty-6.1.x, java 1.6.0_27, Linux (47.7 MB / 96.9 MB)
Hardware Platform: ReadyNAS 102, firmware 6.1.5
Java Memory Limit: ?
Problem Filename: N/A
Output from ffmpeg -i: ?
Last ten log file lines:
[1/3/14 2:14:42 PM CET]    INFO   DaoHelper   Checking database schema.
[1/3/14 2:14:51 PM CET]    INFO   DaoHelper   Done checking database schema.
[1/3/14 2:14:52 PM CET]    INFO   VersionService   Resolved local Subsonic version to: 4.9.beta3
[1/3/14 2:14:56 PM CET]    INFO   MediaScannerService   Deleted old index file: /var/subsonic/subsonic14.index
[1/3/14 2:14:56 PM CET]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Jan 04 00:00:00 CET 2014
[1/3/14 2:14:57 PM CET]    INFO   UPnPService   Starting UPnP service...
[1/3/14 2:14:57 PM CET]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Jan 03 14:19:57 CET 2014
[1/3/14 2:15:07 PM CET]    INFO   UPnPService   Enabling UPnP/DLNA media server
[1/3/14 2:15:07 PM CET]    INFO   UPnPService   Starting UPnP service - Done!
[1/3/14 2:15:07 PM CET]    WARN   NetworkService   Failed to create port forwarding.
[1/3/14 2:19:37 PM CET]    INFO   VersionService   Resolved latest Subsonic final version to: 4.8
[1/3/14 2:19:37 PM CET]    INFO   VersionService   Resolved latest Subsonic beta version to: 4.9.beta3
[1/3/14 2:19:57 PM CET]    INFO   PodcastService   Starting scheduled Podcast refresh.
[1/3/14 2:19:57 PM CET]    INFO   PodcastService   Completed scheduled Podcast refresh.
[1/3/14 2:22:48 PM CET]    WARN   LyricsService   Failed to get lyrics for song 'null'.
[1/3/14 2:22:58 PM CET]    INFO   PlayQueueInputStream   CharlesDuBois listening to "Back to Black (Deluxe Edition)/01 - Amy Winehouse - Back To Black (Deluxe Edition) - Rehab.mp3"
[1/3/14 2:23:11 PM CET]    INFO   PlayQueueInputStream   CharlesDuBois listening to "Frank (2008)/01 - Amy Winehouse - Frank - Intro Stronger Than Me.flac"
[1/3/14 2:23:11 PM CET]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/data/Music/Amy Winehouse/Frank (2008)/01 - Amy Winehouse - Frank - Intro Stronger Than Me.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[1/3/14 2:23:11 PM CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
[1/3/14 2:23:12 PM CET]    INFO   PlayQueueInputStream   CharlesDuBois listening to "Frank (2008)/01 - Amy Winehouse - Frank - Intro Stronger Than Me.flac"
[1/3/14 2:23:12 PM CET]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/data/Music/Amy Winehouse/Frank (2008)/01 - Amy Winehouse - Frank - Intro Stronger Than Me.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[1/3/14 2:23:12 PM CET]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
If transcoding is indeed the problem, then how do I install the transcoders properly? Can this be done by using the ReadyNAS frontview interface? (I am not familiar with ssh and linux).
Karel
Users browsing this forum: Google [Bot] and 13 guests
