No media folders found. Please change the settings.
Postby Princess_Frosty » Sat Jan 04, 2014 9:42 pm
I'm getting this error.
"No media folders found. Please change the settings."
I have the latest subsonic and the latest Java, I'm on windows 8 x64 the drives are available and the permissions are set correctly, I've set the service to run under my user account which has access to all the drives. They're encrypted with TrueCrypt but then they always have been and it's worked fine before, they're mounted as normal volumes, so something is wrong here, how do I troubleshoot this?
Frosty
*edit*
I should add that even after reinstalling it it doesn't see the default C:\music either, it just wont see anything.
No antivirus running...
Princess_Frosty
Re: No media folders found. Please change the settings.
Postby Princess_Frosty » Sat Jan 04, 2014 10:10 pm
Reboot sorted it, sigh...
Princess_Frosty
Users browsing this forum: No registered users and 121 guests
