Jetty error / Corrupt DB possible?
Postby Sculay » Thu Jan 09, 2014 10:46 pm
This is on the latest Subsonic beta with a media over 3-4tb
Getting this upon starting subsonic service
subsonic.log:
[2014-01-09 22:37:39,005] INFO DaoHelper - Checking database schema.
[2014-01-09 22:37:39,347] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:38)
   at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:111)
   at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:68)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
   at java.sql.DriverManager.getConnection(Unknown Source)
   ... 82 more
[2014-01-09 22:37:39,489] INFO VersionService - Resolved local Subsonic version to: 4.9.beta4
[2014-01-09 22:37:40,078] WARN SettingsService - License key is not valid.
[2014-01-09 22:37:40,081] WARN SettingsService - Failed to validate license.
java.lang.NumberFormatException: For input string: "html"
   at java.lang.NumberFormatException.forInputString(Unknown Source)
   at java.lang.Long.parseLong(Unknown Source)
   at net.sourceforge.subsonic.service.SettingsService.validateLicense(SettingsService.java:1270)
   at net.sourceforge.subsonic.service.SettingsService.access$000(SettingsService.java:70)
   at net.sourceforge.subsonic.service.SettingsService$1.run(SettingsService.java:1286)
   at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
   at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Sculay
