Android app connects but doesn't work
Postby cyril0 » Mon Jan 13, 2014 5:48 pm
So my scenario is a bit strange.
I have an ubuntu server running in esxi on a server. This server used to have a public IP and I would access subsonic from the outside world without issues.
I recently moved it behind a firewall and reconfigured the IP to be non routable 192.168.0.124 and did a port forward of 6060 on my router. The web UI works flawlessly from both the router public IP and the non routable when I am on the local network.
The issues is with the android app. I just can't seem to get it to work any longer.
I configure the settings, the test tells me everything is OK, I hit library and it seems to populate but I can not play anything. I just get "A network error occurred" message and the it fails with "please checj the server address and try again later"
The issue I have it is sees the raw folder content. I can actually see the sub folder names and the content in the root library but anything beyond that crashes.
I am guessing it has to do with the change of IP address but I don't know what I should be editing.
Please let me know if you have any suggestions.
cyril0
