Media from another location
Postby tmoran000 » Thu Jan 16, 2014 4:53 am
I am considering getting a dedicated server for my seedbox and to run my Subsonic but it only has a 1tb hard drive and I have about 5 TB of data i want added to the subsonic.. My question is, is it possible to keep my data on my machine and some how stream it to my dedicated server and transcode and send out to the player from the server. not sure if its possible..
What I was thinking if I run a vpn and connect both my machine and the server to and make the folders available in the VPN so on the server side it seemed like a network drive.
i have a 10mb upload so I can push a file at about 1.5mb/s
Could somoene let me know if this is a good idea or if it would even work.. no one answer my last question so I am trying to search other avenues.
tmoran000
Re: Media from another location
Postby pedro_fr » Thu Jan 16, 2014 7:20 pm
you want a plan and command with my sshfs linux?
Envoyé depuis mon GT-N8010
pedro_fr
Postby tmoran000 » Thu Jan 16, 2014 10:51 pm
I dont know linux at all. I was gonna try and learn it but I currently have a VPS server running windows server 2012... i got subsonic working on it but I cant figure out how to get the files linked from my machine to the server that is on a different internet connection
tmoran000
Postby pedro_fr » Fri Jan 17, 2014 12:43 am
Install fuse and sshfs ( on server 3 )
Server B created a directory /var/www/userA
Server B created a directory /var/www/userC
Tape in server B
sshfs root@1.1.1.1:/home /var/www/userA
he will ask the password server A
a security key will be created
if you do not want to enter
echo password | sshfs root@1.1.1.1:/home /var/www/userA -o workaround=rename -o password_stdin
this is a remake of each boot server B
but you can make a spot start
and in case of subsonic
/var/www/userA/nameA
/var/www/userA/nameB
/var/www/userC/nameAAA
under windows can be a virtual linux (eg Cygwin) ?
pedro_fr
Postby pedro_fr » Fri Jan 17, 2014 12:55 am
if your sendbox is under debian you can do the same with (sshfs windows manager)
http://code.google.com/p/win-sshfs/
pedro_fr
Postby tmoran000 » Thu Jan 23, 2014 6:28 am
I am totally lost with the above posts :(
tmoran000
