Reordering and Editing Music Folders
Postby tnt533 » Sun Jan 26, 2014 7:16 pm
I need to be able to edit, add to and reorder my servers music folders which I defined when I set the server up and I see there is no way to do this short of erasing and re-adding them all.
After poking around I noticed that within the /var/subsonic/db folder there is a file named subsonic.script which looks to be where the folders are defined and I was curious if I could edit that file to accomplish my goal without hosing the server. They are listed in that file in the order which I defined them. The actual text is pasted below with names withheld to protect the innocent. =)
INSERT INTO MUSIC_FOLDER VALUES(0,'/home/***/Music/Metal','Metal',TRUE,'2014-01-26 10:50:25.544000000')
INSERT INTO MUSIC_FOLDER VALUES(1,'/home/***/Music/Rock','Rock & Roll',TRUE,'2014-01-26 10:50:25.544000000')
INSERT INTO MUSIC_FOLDER VALUES(2,'/home/***/Music/Classic Rock','Classic Rock',TRUE,'2014-01-26 10:50:25.544000000')
INSERT INTO MUSIC_FOLDER VALUES(3,'/home/***/Music/80''s','80''s Music',TRUE,'2014-01-26 10:50:25.544000000')
INSERT INTO MUSIC_FOLDER VALUES(4,'/home/***/Music/Electronic','Electronic',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(5,'/home/***/Music/Rap - R&B - Soul','Rap, R&B and Soul',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(6,'/home/***/Music/*****''s Music','*****''s Music',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(7,'/home/***/Music/Classical','Classical',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(8,'/home/***/Music/Jazz and Blues','Jazz, Blues and Big Band',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(9,'/home/***/Music/Billboard Top 100 1980 - 2010','Billboard 1980 - 2010',TRUE,'2014-01-26 10:50:25.545000000')
INSERT INTO MUSIC_FOLDER VALUES(10,'/home/***/Music/Pop','Pop',TRUE,'2014-01-26 10:50:25.546000000')
INSERT INTO MUSIC_FOLDER VALUES(11,'/home/***/Music/Country and Folk','Country and Folk',TRUE,'2014-01-26 10:50:25.546000000')
INSERT INTO MUSIC_FOLDER VALUES(12,'/home/***/Music/Movie Soundtracks','Movie Soundtracks',TRUE,'2014-01-26 10:50:25.546000000')
INSERT INTO MUSIC_FOLDER VALUES(13,'/home/***/Music/Unsorted','Unsorted',TRUE,'2014-01-26 10:50:25.546000000')
If I reordered these entries, preserving the structure, would this be an acceptable way to accomplish reordering and adding entries mid-list?
tnt533
Re: Reordering and Editing Music Folders
Postby tnt533 » Mon Feb 03, 2014 9:54 pm
I hate bumping posts but someone has got to know the answer to my question. I can just back up the file and try it but I need to know if there are other unintended consequences I may run into later on or if changing this file will cause changes to be made to other files. I don't want to hose my working system.
Sindre, do you have any input on this? You may very well be the only one who could answer this for me.
tnt533
Users browsing this forum: No registered users and 52 guests
cron
