No Fun Trying to Install Subsonic
Postby zephyr325 » Wed Dec 03, 2008 2:28 am
Hello, all.
I'm a newbie in the Tomcat arena, but pretty familiar with linux/web stuff other than that. I'm running Fedora 8 with Tomcat 5.5 installed on it via the regular OS install - I didn't realize it was already on there.
Anyway, I've done the following to try to get this running:
1) Copied the subsonic.war file to my /var/lib/tomcat5/webapps directory
2) Created a /var/subsonic directory and chown'ed it to be tomcat
3) Restarted the tomcat service
Doing so created a /var/lib/tomcat5/webapps/subsonic directory with lots of files in it. But when I go to my http://myip.com:8080/subsonic weblink, I get literally hundreds of errors that look like this:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP:
JSP FileName:null
Java FileName:/usr/share/tomcat5/work/Catalina/localhost/subsonic//org/apache/jsp/WEB_002dINF/jsp/login_jsp.java
An error occurred at line: 1 in the generated java file
The type java.lang.Object cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.util.List cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.Throwable cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.util.Enumeration cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.Boolean cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
Any thoughts about what I need to be looking at? This is my Tomcat learning experience. :)
zephyr325
Postby zephyr325 » Wed Dec 03, 2008 2:45 pm
I'm imagining this has something to do with my Tomcat / java setup - does anyone have any suggestions of a simple app I can put in there to test if my server is working, or what some troubleshooting steps would be?
Thanks...
zephyr325
AARGH...
Postby zephyr325 » Wed Dec 03, 2008 7:23 pm
OK, I really want to try this program out. :)
I've found out that Fedora 8 (what I'm running) doesn't use Sun's Java, so I have installed and configured Sun's Java to run using this page: http://www.my-guides.net/en/content/vie ... /#sun_java
I verified that's running using the "java -version" command:
[root@Zion subsonic]# java -version
java version "1.6.0_11"
Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
Now that's running (or so I thought), and I've moved away from Tomcat for right now to simplify things and use the Jetty version of Subsonic.
When I run the ./configure.sh, though, I get this error:
[root@Zion subsonic]# ./subsonic.sh
Exception in thread "main" java.lang.NoClassDefFoundError:  -Dsubsonic.contextPath=.
   at gnu.java.lang.MainThread.run(libgcj.so.8rh)
Caused by: java.lang.ClassNotFoundException:  -Dsubsonic.contextPath=. not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:./], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
   at java.net.URLClassLoader.findClass(libgcj.so.8rh)
   at gnu.gcj.runtime.SystemClassLoader.findClass(libgcj.so.8rh)
   at java.lang.ClassLoader.loadClass(libgcj.so.8rh)
Since I'm still seeing libgcj in there, it looks like the Sun java isn't working still.
Has anyone gotten subsonic working on a Fedora machine?
zephyr325
Postby jigsaw » Sun Dec 07, 2008 12:45 pm
I am running Subsonic 3.5 on a Fedora Core release 6 ( Zod ) with Apache Tomcat/6.0.13 and java 1.5.0_11.
I did not install the Fedora Java as I have experienced from my work that we must always use Sun's Java :P
I just put the war in the TOMCAT_HOME/webapps-folder and restarted tomcat. Worked like a charm at once ( I've been using Subsonic since 3.1-beta1 and just upgraded through each release )
I am not familiar with Jetty though, so no help from me there.. But considering Tomcat runs as tomcat you might want to verify that "java -version" gives the correct output as the tomcat-user as well..
jigsaw
