ARR and external remote desktop
Postby Dade334 » Mon Feb 03, 2014 2:48 pm
After following the great tutorial on setting up WAR SS I ran into a problem.
Once completing the step to install ARR I lost the ability to remotely connect to my machines, im guessing it has to do with the reroute IP that is assigned when installing ARR. Anyone help me figure this out? The error I get is that the remote desktop gateway is unavailable, internally on my network it still works great though.
Steps followed:
viewtopic.php?f=6&t=7566
Dade334
Re: ARR and external remote desktop
Postby tsull360 » Wed Feb 05, 2014 5:20 am
I use that same setup for ARR and my remote desktop gateway is still chugging. Double check your setup, are you using ARR on the default site, or on a subfolder? Also, make sure your RD Gateway is still good from a certificate perspective.
tsull360
Users browsing this forum: Google [Bot] and 35 guests
