Third Party SSL not working [Updated w/ Help Request format]
Postby MacDonals » Thu Feb 06, 2014 7:41 pm
I need some help getting my legitimate SSL certificate installed. There are a lot of topics on this board about it, but I have not been able to resolve the issue. I will detail my steps, if anyone can help identify what I’m doing wrong I would greatly appreciate it. (Sorry in advance for the length)
Problem Description: Implementing a valid third party SSL certificate crashes Subsonic / Jetty.
Troubleshooting Steps: FULL deployment steps are outlined below.
Playback Application and version: Standard Subsonic Web Interface
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.7.0_51, Linux (93.7 MB / 125.0 MB)
Hardware Platform: Linux Mint 15 x64 KDE
Java Memory Limit: 200MB
Problem Filename: n/a
Output from ffmpeg -i: n/a
Last ten log file lines: n/a
Full Steps
Setup
    OS: Linux Mint 15 KDE
    Subsonic 4.9
    Domain: dyn.amic.com (not really)
    Hostname: SMITHS
Generated a CSR
I used the following command on SMITHS and specified a challenge password when asked.
openssl req -nodes -newkey rsa:2048 -keyout myserver.key -out server.csr
I then purchased a Comodo PositiveSSL cert ($9!) using the CSR.
Certificates Received
After verifying my domain name I received a zip package containing:
    Root CA Certificate - AddTrustExternalCARoot.crt
    Intermediate CA Certificate - PositiveSSLCA2.crt
    My PositiveSSL Certificate - dyn_amic_com.crt
I combined these three certificates into a cert chain:
cat dyn_amic_com.crt PositiveSSLCA2.crt AddTrustExternalCARoot.crt > cert-chain.txt
PKCS12 File Generation
Next I created a new cert by combining my cert-chain.txt with my private key.
openssl pkcs12 -inkey myserver.key -in cert-chain.txt -export -out subsonic.pkcs12
I am asked for my Export Password, I enter my challenge password. Yay, the subsonic.pkcs12 file is created.
The Keystore.
Now that I have my signed key, I load it into the keystore like so
sudo keytool -importkeystore -srckeystore subsonic.pkcs12 -destkeystore /etc/ssl/certs/subsonic.keystore -srcstoretype PKCS12 -srcalias 1 -destalias subsonic
For destination keystore password I enter subsonic and for source keystore password I enter my challenge password.
Import successful.
Hey Subsonic, use THIS key
I updated the new keystore into the subsonic-booter-jar-with-dependencies.jar
sudo zip /usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar /etc/ssl/certs/subsonic.keystore
No errors, all looks good.
Ports Forwarded
I update my ports
sudo nano /etc/default/subsonic
Set my ports
SUBSONIC_ARGS="--port=4040 --https-port=4043 --max-memory=200"
I’ll restart Subsonic…
sudo service subsonic restart
Then I redirect dyn.amic.com:443 external to SMITHS:4043 in my router
Update the Shell script for starting Subsonic
sudo nano /usr/bin/subsonic
Down with the other -Dsubsonic entries I add
-Dsubsonic.ssl.keystore=/etc/ssl/certs/subsonic.keystore \
-Dsubsonic.ssl.password=subsonic \
And once more
The Test & Failure
From my office I hit https://dyn.amic.com/ and get nothing. When I try to hit http://dyn.amic.com/ I get the
HTTP ERROR: 404
NOT_FOUND
RequestURI=/
Powered by jetty://
What have I done wrong?
MacDonals
Re: Third Party SSL not working [Updated w/ Help Request for
Postby MacDonals » Sun Feb 09, 2014 8:53 pm
I'll answer my own question. I had a few problems apparently.
1) My cert-chain.txt file was incorrect. I should have been using my private key differently, and when I left out the Root cert it worked.
cat myserver.key dyn_amic_com.crt PositiveSSLCA2.crt > subsonic.crt
2) I formated my Linux Mint box and reinstalled Ubuntu Server 12.02 LTS x64. I wasn't sure about having a CLI only OS but this has been fine.
Yay, I'm up on SSL.
MacDonals
