Install 4.9 on Ubuntu
Postby coacharnold » Fri Feb 07, 2014 5:58 pm
I get an install error when I try to upgrade to 4.9 in Ubuntu. Software manager tells me the package is corrupt ... It looks like there's some permissions issues. Is this my issue or the installer?
T
coacharnold
Re: Install 4.9 on Ubuntu
Postby Tanner Williamson » Sat Mar 22, 2014 2:24 am
What version are you attempting to upgrade from? And can you tell me about how you did your last install / upgrade? Are you using a 3rd party repo to get the package, or are you manually downloading the package from the Subsonic SourceForge page and then attempting to install from there?
Tanner Williamson https://www.tannerwilliamson.com/
Tanner Williamson
Users browsing this forum: Google [Bot] and 34 guests
