Can't connect externally
Postby captaincaveman » Sat Feb 08, 2014 10:22 pm
I have SubSonic up and running and can access it using the registered link from within my home network (pazgaz.subsonic.org).
I have set a static IP for the pc on which SubSonic is installed and portfowarding (ports 8085 and 80) to that pc on my router.
CanYouSeeMe.org tells me that port 8085 is open.
I have restarted my router several times and disabled https on Subsonic control panel.
I still cannot access subsonic using pazgaz.subsonic.org:8085 or the <ip from canyouseeme.org>:8085, also tried using my phone (wifi disabled, using 3g) and no success.
I'm out of ideas and would appreciate help. Thanks!
captaincaveman
Re: Can't connect externally
Postby alphawave7 » Sat Feb 08, 2014 10:48 pm
No need for port on the redirect server:
http://pazgaz.subsonic.org
If you do a 'Home' server entry on a client, use the LAN IP WITH the port (192.168.1.13:8085), but WAN only requires your vanity url, unless you run an alternate dynamic dns service.
Postby captaincaveman » Sun Feb 09, 2014 6:27 am
Thanks for the response.
It doesn't work with IP either (using the ip canyouseeme shows and adding the port).
captaincaveman
Postby alphawave7 » Sun Feb 09, 2014 8:52 am
captaincaveman wrote:Thanks for the response.
Your vanity url is working fine, no port entry is needed.
Carefully re-read my post above..it has your functioning vanity url linked and working, and I indicated a port entry is only required when using a LAN IP, not your WAN IP.
Postby captaincaveman » Sun Feb 09, 2014 11:26 am
Thanks! It's working (from work)
captaincaveman
Postby somercamb » Wed Feb 26, 2014 2:28 am
I believe I am having a similar issue. My vanity URL is somercamb.subsonic.org. I cannot access it outside of my home wifi. I check this by turning off my wifi on my phone and try to access it on 4G, but I am not getting through. Here is the odd part: the IP I can access my vanity URL on at home is the WiFi router's IP (begins with 192), but it is not accessible via my external IP (209....). However, I can access my router's setup page via the 192 and 209 IP addresses....
thank you for any help.
somercamb
