Cant login after Musiccabinet install
Postby daz1uk » Wed Feb 12, 2014 12:25 pm
I'm hoping somebody can help me, I have just installed musiccabinet following the instructions on the musiccabinet website but now can't login, I have tried my usual login details and the default, neither work.
Any ideas please?
P.S. my server is running on windows.
I have attached the log file if it helps, thanks.
daz1uk
Re: Cant login after Musiccabinet install
Postby poloismz » Thu Feb 13, 2014 3:07 am
same thing is happening to me now lol
poloismz
Postby tnt533 » Thu Mar 20, 2014 7:29 pm
I am having the same issue as well. I stopped my existing subsonic service, ran the installer for windows and then fired it back up. I get a login screen but none of my credentials work and I can no longer connect to the server from my mobile device. This has been posted for a month now. It would be nice if anyone with any ideas could lend a hand to us newbs here.
EDIT:
I had to do a fresh install to get admin/admin to work as credentials to get into the initial installation. Restoring my c:\subsonic\db folder and my subsonic properties file afterwords recreated the issue of not being able to authenticate so I re-restored the default db directory and the problem went away.
tnt533
Postby jwhitepnv » Sun May 18, 2014 4:30 pm
I am having the same issue. I installed musiccabinet as well and now I can't login. I reinstalled Subsonic and can now login but it won't see my music folder and all my play list are gone. Looks like I will have to go the fresh install route and that really sucks. Has anyone figured this out? It sure would have been nice to seen this response before I installed the add on.
jwhitepnv
Postby rfiveash » Tue Jun 17, 2014 5:08 pm
I'm having this issue, is there a resolution?
Windows 8.1 using different versions of Subsonic from 4.7 through to beta 5
rfiveash
