Yes, it works fine, all my config was fine, routers, modem, etc.
I already check all again and nothing, just can´t connect at all.
Just for me ?
GET http://192.168.0.161:1024/stream?player=6&id=46579 403 (Streaming is forbidden for user admin) Subsonic gives error 403 if the user associated with the player ("admin" in this case) is not authorized to stream music.
As a work-around you can:
- delete the player (from Settings > Players)
- use another user than "admin" (create one in Settings > Users)
alphawave7 wrote:Where exactly is the point of failure? Does canyouseeme.org see your server's port? Does the server run a separate firewall? Did it get updated and lose its permissions? Is your port manually configured from router's interface? Etc. Etc.
My 4.9 server running fine LAN and WAN using vanity URL, so this seems a config issue.
(Since there are several posters in this thread this response is generalised...to get you thinking about methodic investigation towards solution).
jcnaweb wrote:Estado: Successfully forwarding port 4040.
Estado: jcnaweb.subsonic.org is registered, but could not connect to it. (NoRouteToHostException)
Users browsing this forum: Google [Bot] and 35 guests
