Subsonic not connecting error 503
Postby Riffy » Mon Feb 17, 2014 12:20 am
For some reason I now get error 503 whenever I try to connect to my server over the local network or internet, none of the settings have changed. Ports are still set correctly but I just went to add another user and got the error and now I keep getting the error. I have uninstalled and reinstall both java and subsonic twice to make sure. I've attached the log file that does show errors and something about being out of memory which I don't understand since that isn't an issue. Should I be running it with x64 java then? Also saw this Could not connect to RMI service [rmi://localhost:9412/SubsonicDeployerService] - retrying a few times.
Anyway I just need help because it's really bugging me now.
Riffy
Re: Subsonic not connecting error 503
Postby PlayaX » Sat Feb 22, 2014 5:00 pm
Riffy,
The reason you are getting the 503 error is because subsonic is not starting cleanly. Its running out of memory on start up you could look into this. I would start with the JVM option and try to increase the memory there and see if it start up cleanly, but this is just a blind guess till you fix this issue you will not be able to connect to it.
Errors from your logs:
Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 63 out of memory
Caused by: java.sql.SQLException: error in script file line: 63 out of memory
PlayaX
Users browsing this forum: No registered users and 52 guests
