java.lang ERROR MESSAGE jetty/3819
Postby andyf0002 » Wed Feb 26, 2014 2:45 am
java.lang.IllegalArgumentException: Bad temp directory: /Library/Application Support/Subsonic/jetty/3819
Any ideas?
andyf0002
Re: java.lang ERROR MESSAGE jetty/3819
Postby alphawave7 » Wed Feb 26, 2014 5:12 am
Mac?
Postby wlester » Sun Mar 09, 2014 4:25 am
I have this exact same error, new install on a Mac. Any ideas how to fix?
I have tried fixing disk permissions, no luck.
Thanks for any help!
-bill
wlester
Postby alphawave7 » Sun Mar 09, 2014 4:35 am
Try the suggestions in the final two posts:
viewtopic.php?f=2&t=7651&start=15
Postby wlester » Sun Mar 09, 2014 4:57 am
Solved!
I needed to create the folder called /Library/Application Support/Subsonic and then reinstall. Once the Subsonic folder is there, the install creates the jetty subfolder...Worked!
wlester
Users browsing this forum: Google [Bot] and 25 guests
