Subsonic 4.9 Strange Playback Issue
Postby absinth » Thu Feb 27, 2014 12:29 am
Hey Folks:
I just tried searching the forum for my issue but did not see it. I also tried looking through the bug reports on the Source Forge project page but did not see it here either. I am experiencing a strange issue on my Subsonic server via the Web environment after upgrading from 4.8. I am currently running Subsonic 4.9 (premium) standalone on Solaris 11.1. Everything works wonderfully, however, if I browse to an album and attempt to play a single song off of it by clicking the little triangle (small play button) next to the song it plays the song, but then adds the remainder of the album after my selected song to the player/playlist in the bottom pane, which I may or may not want and is annoying. The only way to go around this I found was to click the + sign next to the song to add it directly to the player and click play, then it worked...I looked through the settings to see if I had something set wrong, but everything looks disco. Anyone else experiencing this or know of a fix? Thanks in advance. :|
absinth
Re: Subsonic 4.9 Strange Playback Issue
Postby blueturtles » Thu Feb 27, 2014 1:26 am
What you are experiencing is "normal" as of version 4.9. If you look under the 4.9 announcement thread you will see many others are struggling with the new change just like you are with no work around (that I know of), unless you go back to 4.8. Good luck.
blueturtles
Postby alphawave7 » Thu Feb 27, 2014 5:22 am
blueturtles wrote:What you are experiencing is "normal" as of version 4.9. If you look under the 4.9 announcement thread you will see many others are struggling with the new change just like you are with no work around (that I know of), unless you go back to 4.8. Good luck.
The 'workaround' to play only a single track is to select 'Play Last', which builds no additional playlist.
Postby absinth » Thu Feb 27, 2014 7:27 pm
Well I feel dumb now :P...I will continue to just use the + way that I described earlier. Thanks!
absinth
