[SOLVED]video files wont play only from 1 folder
Postby bruhja » Tue Mar 04, 2014 10:23 pm
Problem Description: Video files wont play from my movies folder but files in my TV folder will play fine. I have tried divx, mkv, avi, mp4. when I click play nothing happens, no errors...nothing its as if the play button simply doesn't work only for files contained in that folder
Troubleshooting Steps: I have rolled my Java back to jre6 as I have read jre7 has issues with subsonic, as well as restarting the service as well as the server. I have also removed the movie folder, cleaned up the database, and then re-added the folder.
Playback Application and version: Webplayer as well as set Subsonic to use an external player. both yield the same result. However the Ultrasonic player for android reports no media found when I click on the file name to play.
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.6.0_37, Windows 7 (118.2 MB / 140.1 MB)
Hardware Platform: Windows professional 7x64
Java Memory Limit: 256
Problem Filename: *.divx, mkv, avi, mp4. only from E:\videos\movies, E:\videos\TV all formats work correctly
Output from ffmpeg -i:
ffmpeg version N-61061-gf34cceb
built on Mar  4 2014 00:49:49 with gcc 4.8.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avis
ynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable
-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype
--enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enabl
e-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-lib
opus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspee
x --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aace
nc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpac
k --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-z
lib
libavutil      52. 66.101 / 52. 66.101
libavcodec     55. 52.102 / 55. 52.102
libavformat    55. 33.101 / 55. 33.101
libavdevice    55. 11.100 / 55. 11.100
libavfilter     4.  2.100 /  4.  2.100
libswscale      2.  5.101 /  2.  5.101
libswresample   0. 18.100 /  0. 18.100
libpostproc    52.  3.100 / 52.  3.100
For help run: ffmpeg -h
For formats run: ffmpeg -formats | more
For codecs run: ffmpeg -codecs | more
Current directory is now: "C:\Users\bruhja\Desktop\ffmpeg-20140304-git-f34cceb-w
in64-static\bin"
The bin directory has been added to PATH
>ffmpeg -i "E:\Videos\Movies\Alien - 3\Alien - 3.mkv"
ffmpeg version N-61061-gf34cceb Copyright (c) 2000-2014 the FFmpeg developers
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
ack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable
-zlib
Input #0, matroska,webm, from 'E:\Videos\Movies\Alien - 3\Alien - 3.mkv':
  Metadata:
    title           : ALIEN3.Title1.DVDRip
    encoder         : libebml v0.7.8 + libmatroska v0.8.1
    creation_time   : 2013-11-18 05:40:06
  Duration: 01:54:53.64, start: 0.000000, bitrate: 1708 kb/s
    Chapter #0.0: start 0.000000, end 222.000000
    Metadata:
      title           : (01)00:00:00:000
    Chapter #0.1: start 222.000000, end 453.000000
    Metadata:
      title           : (02)00:03:42:000
    Chapter #0.2: start 453.000000, end 707.000000
    Metadata:
      title           : (03)00:07:33:000
    Chapter #0.3: start 707.000000, end 881.000000
    Metadata:
      title           : (04)00:11:47:000
    Chapter #0.4: start 881.000000, end 1309.000000
    Metadata:
      title           : (05)00:14:41:000
    Chapter #0.5: start 1309.000000, end 1579.000000
    Metadata:
      title           : (06)00:21:49:000
    Chapter #0.6: start 1579.000000, end 1815.000000
    Metadata:
      title           : (07)00:26:19:000
    Chapter #0.7: start 1815.000000, end 2136.000000
    Metadata:
      title           : (08)00:30:15:000
    Chapter #0.8: start 2136.000000, end 2336.000000
    Metadata:
      title           : (09)00:35:36:000
    Chapter #0.9: start 2336.000000, end 2487.000000
    Metadata:
      title           : (10)00:38:56:000
    Chapter #0.10: start 2487.000000, end 2707.000000
    Metadata:
      title           : (11)00:41:27:000
    Chapter #0.11: start 2707.000000, end 2885.000000
    Metadata:
      title           : (12)00:45:07:000
    Chapter #0.12: start 2885.000000, end 3083.000000
    Metadata:
      title           : (13)00:48:05:000
    Chapter #0.13: start 3083.000000, end 3348.000000
    Metadata:
      title           : (14)00:51:23:000
    Chapter #0.14: start 3348.000000, end 3495.000000
    Metadata:
      title           : (15)00:55:48:000
    Chapter #0.15: start 3495.000000, end 3653.000000
    Metadata:
      title           : (16)00:58:15:000
    Chapter #0.16: start 3653.000000, end 3889.000000
    Metadata:
      title           : (17)01:00:53:000
    Chapter #0.17: start 3889.000000, end 4164.000000
    Metadata:
      title           : (18)01:04:49:000
    Chapter #0.18: start 4164.000000, end 4349.000000
    Metadata:
      title           : (19)01:09:24:000
    Chapter #0.19: start 4349.000000, end 4531.000000
    Metadata:
      title           : (20)01:12:29:000
    Chapter #0.20: start 4531.000000, end 4732.000000
    Metadata:
      title           : (21)01:15:31:000
    Chapter #0.21: start 4732.000000, end 4921.000000
    Metadata:
      title           : (22)01:18:52:000
    Chapter #0.22: start 4921.000000, end 5221.000000
    Metadata:
      title           : (23)01:22:01:000
    Chapter #0.23: start 5221.000000, end 5744.000000
    Metadata:
      title           : (24)01:27:01:000
    Chapter #0.24: start 5744.000000, end 5906.000000
    Metadata:
      title           : (25)01:35:44:000
    Chapter #0.25: start 5906.000000, end 6066.000000
    Metadata:
      title           : (26)01:38:26:000
    Chapter #0.26: start 6066.000000, end 6178.000000
    Metadata:
      title           : (27)01:41:06:000
    Chapter #0.27: start 6178.000000, end 6531.000000
    Metadata:
      title           : (28)01:42:58:000
    Chapter #0.28: start 6531.000000, end 6873.000000
    Metadata:
      title           : (29)01:48:51:000
    Chapter #0.29: start 6873.000000, end 6893.636695
    Metadata:
      title           : (30)01:54:33:000
    Stream #0:0: Video: h264 (High), yuv420p(tv, smpte170m), 720x314, SAR 1:1 DA
R 360:157, 23.98 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
    Stream #0:1(en): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
    Stream #0:2(en): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s
    Stream #0:3(en): Subtitle: dvd_subtitle, 720x314
Last ten log file lines:
[3/4/14 1:49:13 PM PST] INFO DaoHelper Checking database schema.
[3/4/14 1:49:14 PM PST] INFO DaoHelper Done checking database schema.
[3/4/14 1:49:14 PM PST] INFO VersionService Resolved local Subsonic version to: 4.9
[3/4/14 1:49:14 PM PST] INFO PlayerDao Deleted 1 player(s) that haven't been used after Fri Jan 03 13:49:14 PST 2014
[3/4/14 1:49:14 PM PST] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Mar 05 04:00:00 PST 2014
[3/4/14 1:49:14 PM PST] INFO UPnPService Starting UPnP service...
[3/4/14 1:49:14 PM PST] INFO PodcastService Automatic Podcast update scheduled to run every 1 hour(s), starting at Tue Mar 04 13:54:14 PST 2014
[3/4/14 1:49:14 PM PST] INFO UPnPService Enabling UPnP/DLNA media server
[3/4/14 1:49:14 PM PST] INFO UPnPService Starting UPnP service - Done!
[3/4/14 1:49:32 PM PST] INFO PlayerDao Created player 60
This is driving me completely mental
bruhja
Re: video files wont play only from 1 folder
Postby spookybathtub » Wed Mar 05, 2014 3:03 am
Is Subsonic at least listing the files when you refresh the library?
Try copying a file from TV into movies; will it play then?
spookybathtub
Postby bruhja » Wed Mar 05, 2014 3:20 am
Yes the files are listed.
I will try to copy a TV show to the movie folder and play it when I get home from work, and post back.
bruhja
Postby bruhja » Wed Mar 05, 2014 9:14 am
Ok I tried to copy a file from the TV folder to the Movie folder and the new file would not show up refreshing the database or removing and re-adding folder, so I tried to add it as
a folder its self and subsonic reported the folder could not be found.
Long story short it was a permissions issue, I took ownership of the folder refreshed the database and all files now work.
Thanks for the help, I have marked as solved.
bruhja
Users browsing this forum: Google [Bot] and 33 guests
