iSub App issue
iSub App issue
Postby tripaphonic » Thu Mar 13, 2014 12:54 am
Hey community. Having a strange problem. I have subsonic installed on a Windows Server 2012 Standard box and it works great over the net but when I use the iSub app on my iPhone 5 it acts up. I can go to Shuffle and choose a category and it acts as though it's loading but shows nothing when it loads. It's like it loads a blank playlist. The user I am set up with is an admin on subsonic and has all the flags for every permission. I've deleted the app from my phone and restarted several times. Not sure what's up.
tripaphonic
Re: iSub App issue
Postby gurutech » Thu Mar 13, 2014 1:00 am
Try with wifi disabled. I had similar problems if I was on the same network as my server (aka, at home). Forcing the connection over 3G seemed to fix the problem, at least for me...
gurutech
Re: iSub App issue
Postby Tanner Williamson » Sat Mar 22, 2014 2:12 am
Also make sure you check out the support site by the author of iSub app. http://isubapp.com/forum/
At this point I'm not sure if it's an issue with Subsonic, or the app, but I hope that gives you another resource to check out :)
Tanner Williamson https://www.tannerwilliamson.com/
Tanner Williamson
