SQL error (since some time now...)
Postby ldecorps » Thu Mar 13, 2014 10:50 pm
Hi there,
this is what I get when I try to read the library (for playing a tune for instance)...
I can only play some of my lib, most of it fails with the below error:
Cheers
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
Java version Oracle Corporation 1.7.0_40
Server jetty-6.1.x
Memory Used 24 of 39 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:221)
at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:272)
at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:158)
at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:88)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
... 65 more
ldecorps
Re: SQL error (since some time now...)
Postby alphawave7 » Thu Mar 13, 2014 10:59 pm
S1000 error suggests corrupt database. Some users have reported deleting java and re-installing it has cured the problem without actually deleting the database, which of course would require rebuilding it (users,etc. deleted). Give the Java delete/reinstall a chance first.
Postby ldecorps » Fri Mar 14, 2014 8:50 pm
Hi there,
I did the uninstall and delete of java, reinstalled, same error.
So I suppose now I must remove subsonic and reinstall, would that do the trick?
>> Actually I just did that, and I still got the error, and here is the log:
[3/15/14 10:03:02 AM GMT] INFO DaoHelper Checking database schema.
[3/15/14 10:08:18 AM GMT] INFO Schema47 Database table 'media_file' not found. Creating it.
[3/15/14 10:08:18 AM GMT] ERROR DaoHelper Failed to initialize database.
[3/15/14 10:08:35 AM GMT] INFO VersionService Resolved local Subsonic version to: 4.9
Cheers
ldecorps
Postby mbro » Sat Mar 15, 2014 9:51 pm
You might be experiencing a similar issue to what I was. For me, it was the media indexer that was failing. Here's the post about my issue and resolution:
viewtopic.php?f=2&t=10172
I don't think uninstalling java and subsonic is going to do it for you, but you can try my fix and see if it works for you.
mbro
Users browsing this forum: Google [Bot] and 35 guests
