Subsonic bound to new ip address after upgrade
Postby hegleran » Wed Mar 19, 2014 3:56 pm
Problem Description:After upgrading to 4.9, subsonic is now bound to a new ip address that I do not see configured on my server. I can still access the server from the old ip address. This does not break anything, but I do not understand why it is bound to the new address all of a sudden. I would prefer to have the application bound to the address that I have configured on my eth0 interface.
Troubleshooting Steps: I grepped through /var/subsonic for any pattern matching the new address, and don't see anything. I do not see an adapter configured with this address on the OS (Ubuntu). I see the new IP address in my router's arp cache bound to the same mac address as the static IP address that I have configured on the server's eth0 interface.
Playback Application and version: Not really applicable, but I play from iSub, Ultrasonic, The Subsonic app for Roku, and the web interface.
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.7.0_51, Linux (128.0 MB / 263.0 MB)
Hardware Platform: Ubuntu Linux 3.2.0-60-generic #91-Ubuntu SMP Wed Feb 19 03:54:44 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar) ==> Not sure if applicable, but how would I find this in Linux?
Problem Filename: (If you are having difficulty with a particular file, please include it's name) Not applicable.
Output from ffmpeg -i:
ffmpeg -i ~/Music/The\ Rolling\ Stones-Sticky\ Fingers/01.Brown\ Sugar.mp3
ffmpeg version 0.8.10-4:0.8.10-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
  built on Feb  6 2014 20:56:59 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[mp3 @ 0x10d89c0] max_analyze_duration reached
Input #0, mp3, from '/home/USERNAME/Music/The Rolling Stones-Sticky Fingers/01.Brown Sugar.mp3':
  Metadata:
    album           : Sticky Fingers
    artist          : The Rolling Stones
    title           : Brown Sugar
    track           : 01/10
    genre           : Rock
    date            : 1971
  Duration: 00:03:49.79, start: 0.000000, bitrate: 280 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 280 kb/s
Last ten log file lines:
tail -n 10 /var/subsonic/subsonic.log
hegleran
Re: Subsonic bound to new ip address after upgrade
Postby pinkmoon » Mon Mar 24, 2014 4:34 pm
Could this be in anyway connected to why I've been unable to connect remotely in Win8 approx since time I update subsonic OR java..?
viewtopic.php?f=2&t=14211&p=62226#p62226
pinkmoon
