Video transcoding not performed when accessing via Android
Postby morespray » Sat Apr 05, 2014 9:37 pm
Hi, I'm having trouble to understand how the Player transcoding settings are applied when accessing videos (mkv) via the Android client. To be clear, I'm refering to Subsonic for Android developed by Sindre. Afaict, they are not applied at all - as there is no ffmpeg process started on the server when I'm streaming on Android and there is when I use a web player.
I have created a player 'External player with playlist' and enabled the video transcoding I want to use. On the Status page it shows that the correct player is being used - "android [xxx] (VLC/2.2.0-git LibVLC/2.2.0-git)" - but no transcoding is taking place. Transcoding works fine when I use a web browser Player which has the same transcoding option selected.
Server Hardware Platform: Windows7
Java Memory Limit: 100MB
Last ten log file lines:
[2014-04-05 23:21:00,600] INFO StreamController - Got range: Range[0,9223372036854775807]
[2014-04-05 23:21:00,628] INFO PlayQueueInputStream - xxx listening to "cartoons\archer.2009.s05e01.720p.hdtv.x264-killers.mkv"
[2014-04-05 23:21:00,679] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
   at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
   at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
   at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
   at net.sourceforge.subsonic.io.RangeOutputStream.write(RangeOutputStream.java:143)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1172)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:108)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:55)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
Caused by: java.io.IOException: An existing connection was forcibly closed by the remote host
   at sun.nio.ch.SocketDispatcher.write0(Native Method)
   at sun.nio.ch.SocketDispatcher.write(Unknown Source)
   at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
   at sun.nio.ch.IOUtil.write(Unknown Source)
   at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
   at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
   at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
   ... 69 more
More than 10 lines of log, I know. I don't understand the Exceptions - the video plays fine, only it's not being transcoded.
morespray
Re: Video transcoding not performed when accessing via Andro
Postby 007bond007 » Fri Apr 11, 2014 11:21 pm
Same happens for me, I'm thinking it may be a bug, I've tried using many different transcoding options as well and even if you switch the command it won't error out.
007bond007
