Playing music in Subsonic causes disconnections/latency
Postby GH0 » Sun Apr 13, 2014 9:47 pm
Alright, so after INTENSIVE testing to try and figure out why and what is causing my constant disconnections from other services that I host. I have finally found the issue is subsonic. As if I don't play a single song on subsonic (and instead use pandora), I don't have any issues with disconnecting at all during the day.
This problem occurs when I am playing a new song (it doesn't matter what size/length), but until the entire song is transferred and loaded so that I can play it seamlessly in subsonic, I have intermittent connectivity issues to any service that I am hosting on that same box. This doesn't occur with any other service (Plex, Apache websites, znc, etc). If a new song loads, I am sometimes disconnected from services I am already connected to.
I thought setting a upload/download quota would help fix this, so I set it to 1/4 of the bandwidth that I pay for (my bandwidth is generally consistent), yet I still run into the issue. I am not sure why it disconnects me/doesn't let me access the services, but it is mildly annoying. Subsonic itself fails to properly work as well since I can't load some of the interface due to the issue.
I run subsonic behind Apache2 using proxypass and proxypassreverse. I have attached some of the pictures that I am referring to the load bar, and then the services disconnecting (it isn't just one,but this was the easiest to take a picture for at the time.
I don't have physical access to the server at the moment, but I can get it, if I need a console connection while I replicate the issue.
Playback Application:
Web Interface / Potentially any interface that downloads songs
Subsonic Version
Version 4.9 (build 3853) – January 23, 2014
Server Information
Server jetty-6.1.x, java 1.7.0_51, Linux - Ubuntu 12.04.4 LTS
Java Memory Limit
(71.7 MB / 136.0 MB)
The log file during this occured (I just have a bunch of other junk in older lines that I know isn't relevant to the issue)
[4/13/14 5:23:51 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'Rather Be (feat. Jess Glynne)' for user volumus at Last.fm: Sun Apr 13 17:23:44 EDT 2014
[4/13/14 5:24:20 PM EDT] DEBUG AudioScrobblerService Successfully registered submission for song 'Rather Be (feat. Jess Glynne)' for user volumus at Last.fm: Sun Apr 13 17:24:13 EDT 2014
[4/13/14 5:27:32 PM EDT] INFO PlayQueueInputStream GH0 listening to "DJ Abilities/Dj Abilities - NOW! That's What I Call Fuck Off.mp3"
[4/13/14 5:28:44 PM EDT] INFO AudioScrobblerService Last.fm registration for NOW! That's What I Call Fuck Off. encountered network error. Will try again later. In queue: 1
[4/13/14 5:30:56 PM EDT] INFO AudioScrobblerService Last.fm registration for NOW! That's What I Call Fuck Off. encountered network error. Will try again later. In queue: 1
[4/13/14 5:33:08 PM EDT] INFO AudioScrobblerService Last.fm registration for NOW! That's What I Call Fuck Off. encountered network error. Will try again later. In queue: 1
[4/13/14 5:34:15 PM EDT] DEBUG AudioScrobblerService Successfully registered now playing for song 'NOW! That's What I Call Fuck Off.' for user volumus at Last.fm: Sun Apr 13 17:27:32 EDT 2014
[4/13/14 5:34:21 PM EDT] DEBUG AudioScrobblerService Successfully registered submission for song 'NOW! That's What I Call Fuck Off.' for user volumus at Last.fm: Sun Apr 13 17:33:34 EDT 2014
Output from ffmpeg -i:
@server:~$ ffmpeg -i /media/stor/music/Music/DJ\ Abilities/Dj\ Abilities\        -\ NOW\!\ That\'s\ What\ I\ Call\ Fuck\ Off.mp3
ffmpeg version 0.8.10-4:0.8.10-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Lib        av developers
  built on Feb  6 2014 20:56:59 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future        release. Please use avconv instead.
[mp3 @ 0xf8e7a0] max_analyze_duration reached
[mp3 @ 0xf8e7a0] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '/media/stor/music/Music/DJ Abilities/Dj Abilities - NOW! Th        at's What I Call Fuck Off.mp3':
  Metadata:
    title           : NOW! That's What I Call Fuck Off.
    artist          : DJ Abilities
    album_artist    : DJ Abilities
    TCM             : DJ Abilities
    album           : NOW! That's What I Call Fuck Off.
    track           : 1/1
    encoded_by      : iTunes 10.5.3
    genre           : Mixtape
    date            : 2012
  Duration: 00:51:16.91, start: 0.000000, bitrate: 255 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 256 kb/s
(The above is an example of one of the files that can cause this problem, it isn't file specific)
GH0
Re: Playing music in Subsonic causes disconnections/latency
Postby GH0 » Sun Apr 20, 2014 3:01 am
Bump, this is still a problem. I didn't mention it earlier but the bandwidth I pay for is 20 Mbit down, and 2Mbit up. I have limited Subsonic to 256 Kbit to try and resolve these issues, but they still occur.
GH0
