org.springframework.jdbc.BadSqlGrammarException for one user
Postby KBanause » Wed Apr 16, 2014 7:19 am
all of a sudden I get a org.springframework.jdbc.BadSqlGrammarException exception when connecting to Subsonic using a browser. I can log in but then this error is displayed.
Interesting, that it does affect only one user. Admin account and other users are not affected only the one that has the same username as the one running the subsonic server (could be a coincidence).
Only the webinterface has problems, using DSub I can browse my library and play music.
Server:
Subsonic 4.9 (Debian/Ubuntu .deb package)
Ubuntu 12.04 LTE Server
$ java -version
java version "1.7.0_51"
OpenJDK Runtime Environment (IcedTea 2.4.4) (7u51-2.4.4-0ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 24.45-b08, mixed mode)
I tried to uninstall (with removing the /var/subsonic directory) and reinstall it, but even then I get the same error with the same username.
Stacktrace:
org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
   at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
   at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
   at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
   at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:175)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:94)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:64)
   at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:51)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
   at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
   at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
   at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
   at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
   at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646)
   ... 64 more
KBanause
Re: org.springframework.jdbc.BadSqlGrammarException for one
Postby KBanause » Wed Apr 16, 2014 7:26 am
Strange. After deleting all cookies for the domain my subsonic is available at, the error doesn't pop up anymore.
KBanause
Postby greglox » Tue Aug 05, 2014 7:10 pm
I can second the fact that deleting my browser cookies (Chrome browser at work) made Subsonic work. I also found that the admin account didn't have the issue. I had removed the application, removed /var/subsonic, re-installed and still had the issue...clearing cookies was the solution.
greglox
