[Solved] Subsonic Standalone behind Apache ReverseProxy
Postby daily-freak » Mon May 12, 2014 10:25 am
Hello there,
i recently installed the stand-alone version of subsonic on my gentoo-server. Now I have a strange problem I don't understand.
I configured subsonic for http. In addition I use Apache2 as ReverseProxy for the jetty included in subsonic stand alone. This Apache is accessable over the internet, but only with ssl. Below are my configuration-files of subsonic and the relevant parts of the apache.
Now my problem: Generally subsonic is working. Also over the internet/dyndns. But some functions are not working. For example the Settings-Button in the top.view. The link this button leads to is to the "settings.view?".
* If I enter this link "https://my.domain.com/subsonic/settings.view" the response is very slow.
* After some time the URL changes to "http://my.domain.com/subsonic/playerSettings.view". This sort of redirect is done in jetty I think. You notice that https became http. I get a 404.
* If I now manually change the URL from http to https the page is shown
It seems like the redirecting done in jetty leads to a wrong returned URL. And I don't understand why. As I see the configuration should be correct.
If I directly access the jetty in my LAN and bypass the apache everything also works fine. So it must be some thing between the stand alone jetty and the apache. I don't know what to do so any help or suggestions would be much appreciated.
Greetings daily
Edit: The same problem seems to Affect the "More Actions"-Dropdown like Downloading, adding a song to a playlist etc.
subsonic.sh
SUBSONIC_HOME=/mnt/raid0/subsonic/bin/data
SUBSONIC_HOST=0.0.0.0
SUBSONIC_PORT=8085
SUBSONIC_HTTPS_PORT=0
SUBSONIC_CONTEXT_PATH=/subsonic
SUBSONIC_MAX_MEMORY=150
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/mnt/raid0/subsonic/audio
SUBSONIC_DEFAULT_PODCAST_FOLDER=/mnt/raid0/subsonic/podcasts
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/mnt/raid0/subsonic/playlists
Virtual-Host
<IfModule mod_proxy.c>
        ProxyRequests Off
        ProxyVia On
        ProxyPreserveHost On
        <Proxy *>
                AddDefaultCharset off
                Allow from all
        </Proxy>
</IfModule>
<IfDefine SSL>
        <IfDefine SSL_DEFAULT_VHOST>
                <IfModule ssl_module>
                Listen 443
                NameVirtualHost *:443
                </IfModule>
        </IfDefine>
</IfDefine>
ServerAdmin root@myserver
Listen 80
NameVirtualHost *:80
<VirtualHost *:80>
        RewriteEngine On
        RewriteCond %{HTTPS} !on
        RewriteCond %{REQUEST_URI} !^/server-status
        RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
       <Location /server-status/>
                 SetHandler server-status
                 Order Deny,Allow
                 Deny from all
                 Satisfy Any
                 Allow from 127.0.0.1
                #Allow from All
        </Location>
</VirtualHost>
<IfDefine SSL>
<VirtualHost *:443>
        ServerName my.domain.com
        ServerAlias myserver
        SSLEngine on
        SSLProxyEngine on
        SSLCertificateFile /etc/ssl/apache2/my.domain.com.crt
        SSLCertificateKeyFile /etc/ssl/apache2/my.domain.com.key
        SSLOptions StrictRequire
        SSLProtocol all -SSLv2
        DocumentRoot "/var/www/localhost/htdocs"
        FilterProvider gzdeflate DEFLATE Content-Type $text/
      <IfModule mod_fastcgi.c>
           Alias /php5.fastcgi /var/www/fastcgi/php5.fastcgi
           AddHandler php-script .php
           FastCGIExternalServer /var/www/fastcgi/php5.fastcgi -socket /var/run/php-fpm-localhost.sock$
           Action php-script /php5.fastcgi virtual
      # This part is not necessary to get it to work, but it stops anything else from being
      # accessed from it by mistake or maliciously.
           <Directory "/var/www/fastcgi">
                   Order allow,deny
                   <Files "php5.fastcgi">
                           Order deny,allow
                   </Files>
           </Directory>
      </IfModule>
        <IfModule mpm_peruser_module>
                ServerEnvironment apache apache
        </IfModule>
        <IfModule authnz_external_module>
                AddExternalAuth pwauth  /usr/sbin/pwauth
                SetExternalAuthMethod   pwauth  pipe
                AddExternalGroup unixgroup /usr/sbin/unixgroup
                SetExternalGroupMethod unixgroup environment
        </IfModule>
      <Directory "/var/www/localhost/cgi-bin">
                SSLRequireSSL
                Options FollowSymLinks
                Order deny,allow
                Allow from all
                AuthType Basic
                AuthName "This is private"
                AuthBasicProvider external
                AuthExternal pwauth
                GroupExternal unixgroup
                Require user dailyfreak
        </Directory>
        <Directory /var/www/localhost/htdocs>
                SSLRequireSSL
                Options Indexes FollowSymLinks
                #FilterChain +gzdeflate
                Order deny,allow
                Allow from all
                AuthType Basic
                AuthExternal pwauth
        </Directory>
      <Location /subsonic>
         SSLRequireSSL
         Order deny,allow
         Allow from all
         AuthType Basic
         AuthExternal pwauth
         ProxyPass http://127.0.0.1:8085/subsonic
         ProxyPassReverse https://my.domain.com/subsonic
      </Location>
</VirtualHost>
</IfModule>
</IfDefine>
</IfDefine>
daily-freak
Re: Subsonic Standalone behind Apache ReverseProxy -> Proble
Postby daily-freak » Tue May 13, 2014 6:56 am
I finaly got this working. I simply needed to switch off ProxyPreserveHost in the Apache-Config. After this the problem was solved.
Greetings
daily-freak
