Video streaming issue...
Postby Jigar » Fri May 16, 2014 8:42 pm
My movies streaming not working smoothly from WebUI. It pause(loading for few seconds\min) and play again for few min. :( . This is happening for all times.
I am using 4.9 version on Linux(Ubuntu 12.04.4 LTS).
Please guide.
Thank you.
Jigar
[5/16/14 4:32:15 PM EDT]   INFO   PlayQueueInputStream   admin listening to "30 Days Of Night (2007)/30 Days Of Night (1080p).mkv"
[5/16/14 4:32:15 PM EDT]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/media/usb/Movies/New Movies/30 Days Of Night (2007)/30 Days Of Night (1080p).mkv] [-async] [1] [-b] [1000k] [-s] [640x268] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [matroska,webm @ 0x96c1be0] max_analyze_duration 5000000 reached at 5002000
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [matroska,webm @ 0x96c1be0] Estimating duration from bitrate, this may be inaccurate
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Input #0, matroska,webm, from '/media/usb/Movies/New Movies/30 Days Of Night (2007)/30 Days Of Night (1080p).mkv':
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Metadata:
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) title : 30 Days of Night (2007) - Encoded by Pioneer
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Duration: 01:53:05.73, start: 0.000000, bitrate: 1536 kb/s
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [SAR 400:399 DAR 320:133], SAR 255:254 DAR 306:127, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.2(eng): Subtitle: pgssub
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [buffer @ 0x9710220] w:1920 h:800 pixfmt:yuv420p tb:1/1000000 sar:255/254 sws_param:
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [scale @ 0x9825f80] w:1920 h:800 fmt:yuv420p -> w:640 h:268 fmt:yuv420p flags:0x4
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9768940] using SAR=255/254
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9768940] using cpu capabilities: MMX2 SSE2 SSE3 Cache64
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9768940] profile High, level 2.1
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9768940] 264 - core 116 r2044 392e762 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0(eng): Video: libx264, yuv420p, 640x268 [SAR 255:254 DAR 20400:8509], q=2-31, 1000 kb/s, 1k tbn, 23.98 tbc (default)
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s (default)
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[5/16/14 4:32:15 PM EDT]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Input stream #0.1 frame changed from rate:48000 fmt:s16 ch:6 to rate:48000 fmt:s16 ch:2
Jigar
