2 problems with Subsonic Player Android App
Postby talonzme » Mon May 19, 2014 12:04 am
First issue. When running server version 4.8 the music would not play or download to phone. Settings does not give me the option to change the cache directory. I read about the changes in SDCard permissions with KitKat and the DSub player being the fix. I don't want to have to purchase another app to be able to play my music.
I upgraded the server to version 4.9 and now I get a SQL error when I try to open music in the library on the android app.
talonzme
Re: 2 problems with Subsonic Player Android App
Postby Boulou » Tue May 20, 2014 3:27 pm
i can't change the directory either... :(
that's very annoying
using cyanogenmod 11 (android 4.4.2)
Boulou
Postby talonzme » Tue May 20, 2014 4:31 pm
Stock kitkat on note 3
Sent from my Note 3 using Tapatalk
talonzme
Postby talonzme » Tue May 20, 2014 6:56 pm
Tested the Android app with the demo server and it works.
talonzme
Postby talonzme » Wed May 21, 2014 6:38 pm
Is there a fix I need to perform on the server itself?
talonzme
Postby daneren2005 » Wed May 21, 2014 9:00 pm
If you are getting sql errors, it is a problem with the server, not the app.
Postby talonzme » Wed May 21, 2014 9:29 pm
Bummer, I suppose that means an Uninstaller and reinstall
talonzme
Postby talonzme » Thu May 22, 2014 9:56 pm
Below is the error log for the Subsonic server relating to the SQL error when accessed.
Exception   org.springframework.jdbc.BadSqlGrammarException
Message   PreparedStatementCallback; bad SQL grammar [select name, song_count, album_count from genre order by song_count desc]; nested exception is java.sql.SQLException: Table not found in statement [select name, song_count, album_count from genre order by song_count desc]
Java version   Oracle Corporation 1.7.0_55
Operating system   Windows Server 2008 R2 6.1
Server   jetty-6.1.x
Memory   Used 46 of 75 MB
Stack trace   org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select name, song_count, album_count from genre order by song_count desc]; nested exception is java.sql.SQLException: Table not found in statement [select name, song_count, album_count from genre order by song_count desc]
   at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220)
   at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
   at net.sourceforge.subsonic.dao.MediaFileDao.getGenres(MediaFileDao.java:178)
   at net.sourceforge.subsonic.service.MediaFileService.getGenres(MediaFileService.java:239)
   at net.sourceforge.subsonic.controller.MoreController.handleRequestInternal(MoreController.java:66)
Caused by: java.sql.SQLException: Table not found in statement [select name, song_count, album_count from genre order by song_count desc]
   at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
   at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
   at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585)
   ... 61 more
talonzme
Postby talonzme » Mon May 26, 2014 7:18 pm
I have since tried uninstalling and reinstalling the Subsonic server with no benefit or resolution. The same error is still shown.
talonzme
Postby talonzme » Tue Jun 24, 2014 6:28 pm
I did finally get it to work. I had to delete the existing db and backups and then reestablish the library in subsonic. Any apps that were connected had to be removed and reinstalled to get the db contents correct.
Sent from my SM-N900V using Tapatalk
talonzme
Postby adamrabin » Wed Jun 25, 2014 6:04 pm
Has anybody had success regarding the inability to change the cache location in the Android app?
adamrabin
Postby talonzme » Wed Jun 25, 2014 6:05 pm
Not that I have seen
talonzme
Postby adamrabin » Thu Jun 26, 2014 1:00 pm
I switched to the UltraSonic app for Android. All set!
adamrabin
