Exceptions in Log file
Postby Josh Hawley » Tue May 20, 2014 2:19 am
Problem Description: Can not get subsonic to play on andriod (plays on windows phone and ios) I found the errors in the log listed below, and thought it may be related.
Troubleshooting Steps: Updated to 4.9, searched forums for errors in log below
Playback Application and version: Subsonic (andriod app) version from the play store
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.7.0_21, Windows Server 2008 (65.2 MB / 78.3 MB)
Hardware Platform: Windows Server 2008 SBS
Java Memory Limit: 150MB (currently using 67MB)
Problem Filename: same problem with all files and file types
Output from ffmpeg -i:
Last ten log file lines:
46 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@19da4fc: display name [org.springframework.context.support.ClassPathXmlApplicationContext@19da4fc]; startup date [Mon May 19 18:58:57 PDT 2014]; root of context hierarchy
124 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
624 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@19da4fc]: org.springframework.beans.factory.support.DefaultListableBeanFactory@e7736c
639 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@e7736c: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
671 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: C:\subsonic\subsonic.war
Extracting webapp to c:\subsonic\jetty\3853
717 [main] INFO org.mortbay.log - jetty-6.1.x
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/subsonic/jetty/3853/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
1232 [main] INFO / - Initializing Spring root WebApplicationContext
1248 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
1263 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@4654f6: display name [Root WebApplicationContext]; startup date [Mon May 19 18:58:58 PDT 2014]; root of context hierarchy
1326 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
1404 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
1451 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
1466 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@4654f6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1439515
1560 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1439515: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,musicInfoService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache]; root of factory hierarchy
1622 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
3681 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
3697 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
3697 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
3697 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
3728 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 2480 ms
3775 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
3775 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
3775 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@195683: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Mon May 19 18:59:01 PDT 2014]; parent: org.springframework.web.context.support.XmlWebApplicationContext@4654f6
3775 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
3822 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@195683]: org.springframework.beans.factory.support.DefaultListableBeanFactory@11d4da2
3884 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@11d4da2: defining beans [leftController,rightController,statusController,mainController,playlistController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastReceiverController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,hlsController,videoPlayerController,externalPlayerController,downloadController,premiumController,multiController,wapController,restController,dbController,premiumValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@1439515
4649 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 874 ms
4664 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:6969
Subsonic running on: http://localhost:6969/
4711 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
4945 [btpool0-1] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0.116.rc1 on jetty-6.1.x / JDK 1.7.0_21 from Oracle Corporation at
5710 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
5741 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[10.0.2.5:9412](local),objID:[0:0:0, 0]]]]
72029 [btpool0-2] ERROR org.mortbay.log - /rest/stream.view
72029 [btpool0-8] ERROR org.mortbay.log - /rest/stream.view
72029 [btpool0-9] ERROR org.mortbay.log - /rest/stream.view
72029 [btpool0-7] ERROR org.mortbay.log - /rest/stream.view
72029 [btpool0-12] ERROR org.mortbay.log - /rest/stream.view
72029 [btpool0-5] ERROR org.mortbay.log - /rest/stream.view
java.lang.IllegalStateException: STREAM
   at org.mortbay.jetty.Response.getWriter(Response.java:583)
   at net.sourceforge.subsonic.controller.RESTController.error(RESTController.java:1979)
   at net.sourceforge.subsonic.filter.RESTFilter.handleException(RESTFilter.java:73)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:60)
72044 [btpool0-10] ERROR org.mortbay.log - /rest/stream.view
72044 [btpool0-4] ERROR org.mortbay.log - /rest/stream.view
72044 [btpool0-13] ERROR org.mortbay.log - /rest/stream.view
72044 [btpool0-6] ERROR org.mortbay.log - /rest/stream.view
72044 [btpool0-11] ERROR org.mortbay.log - /rest/stream.view
113230 [btpool0-2] ERROR org.mortbay.log - /rest/stream.view
Josh Hawley
Re: Exceptions in Log file
Postby jas_raj » Mon May 26, 2014 8:13 pm
It seems that you are getting the same errors as I am getting (http://forum.subsonic.org/forum/viewtopic.php?f=2&t=14385).
Not sure what the issue is here - hoping for a response from one of the devs soon.
jas_raj
Users browsing this forum: Google [Bot] and 17 guests
