Mac transcoders didn't install - how can I get them?
Postby realish » Sat May 24, 2014 11:54 pm
Downloaded the latest Mac installer (4.9 (build 3819)). First attempt at run failed -- I had to manually create an /Application Support/Subsonic folder, set permissions, and reinstall. Second time it started up fine.
Unfortunately, it looks like the transcoder didn't install (the Subsonic/transcode folder is empty).
I've looked around the forum but cant seem to find a simple answer: can I install it manually? And if so, how?
realish
Re: Mac transcoders didn't install - how can I get them?
Postby GJ51 » Sun May 25, 2014 12:23 am
Postby realish » Sun May 25, 2014 6:11 am
That did it! Thanks much.
realish
Postby c0manche » Mon Jun 09, 2014 7:59 pm
No use that link only has the windows transcoders could not find transcoders for osx Any help appreciated cheers
c0manche
Postby GJ51 » Mon Jun 09, 2014 8:35 pm
