m4a Apple purchased songs don't play (FFMpeg issue)
Postby mannnyhenri » Mon May 26, 2014 5:29 pm
I've just installed my server on my mac and it works beautifully for some songs but others aren't working (both on my mobile or web app). What's the problem???? It seems to be any MP4 songs with the m4a extension, so in other words the Apple lossless format conversion to MP3 doesn't seem to work...
I'm running Subsonic 5.0 beta (4.9 doesn't seem to work) on Mac OSX 10.9 Maverick. Android kitkat 4.4 on my Nexus device.
mannnyhenri
Re: m4a Apple purchased songs don't play (FFMpeg issue)
Postby mannnyhenri » Thu May 29, 2014 7:10 pm
Anyone??? Solution???? :oops:
mannnyhenri
Postby c0manche » Wed Jun 04, 2014 3:59 pm
I am having the same problem with 5.0 beta 1 on OSX Mavericks my m4a (non drm) used to work in the past now they don't play on web portal or in android app
seem to be a serious bug in the osx version of subsonic
c0manche
Postby syk » Thu Jun 05, 2014 2:21 pm
I'm having the same issue. The only way they seem to work is if you skip forward 30 seconds into the song - not really a solution though.
syk
Postby syk » Wed Jun 11, 2014 8:34 pm
My fix was to downgrade to 4.9 - all files play fine now.
syk
Postby ian3d » Wed Jun 25, 2014 4:58 pm
Just wanted to bump this. I'm using version 5.0.beta1 (build 4048) for Ubuntu and having the same issue.
This is in the subsonic.log
[2014-06-25 09:45:58,370] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/[PATH].m4a] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
ian3d
Postby syk » Sat Sep 13, 2014 9:15 pm
This is still broken with 5.0 beta 2. The only solution is to copy the ffmpeg file from a 4.9 install and overwrite the new ffmpeg which is installed in 5.0 beta 2 (or b1).
It lives in /var/subsonic/transcode/ in linux
syk
Postby ian3d » Fri Sep 26, 2014 3:12 pm
I just updated to 5.0 Stable (debian) and this issue seems to be resolved. It looks like the correct ffmpeg transcoder was included this time. Thanks!
[9/26/14 10:07:01 AM CDT]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/[filename].m4a] [-map] [0:0] [-b:a] [128k] [-v] [0] [-f] [mp3] [-]
EDIT: This is written in the log and the files play correctly.
ian3d
Postby fatcat46 » Tue Apr 14, 2015 7:32 pm
Not working for me Subsonic version 5.2.1 (build 4428).
How do I fix this.
Fatcat46
fatcat46
