Installation Help Ubuntu 14.04
Postby barrecan » Wed Jun 04, 2014 1:45 am
Hey,
I have successfully installed Subsonic before, but after I uninstalled and tried to reinstall, it stopped working. I believe the problem is that I don't have permission to access the subsonic files from my old installation. I am fairly new to linux so troubleshooting is a bit difficult for me. I tried to delete the remaining /etc/default/subsonic directory but it says the directory does not exist, although I can view it when I "ls -a". Image
I "succesfully" apt-get removed Subsonic but when I tried to reinstall, it throws a chown error. Image
If anyone can help me completely delete the old installation so I can succesful reinstall it would be greatly appreciated.
thanks -
barrecan
Re: Installation Help Ubuntu 14.04
Postby daneren2005 » Wed Jun 04, 2014 2:29 am
I don't know about the rest of your problem, but I can tell you the first issue is that you aren't able to cd into the directory because it's a file, not a directory :D
Postby ian3d » Wed Jun 25, 2014 5:25 pm
You might just need to do this with root permissions if you current user does not have access. Add 'sudo' before your command to execute it with root.
If that does not work I would check the permissions of the files. You can do 'ls -la' to give a list format with more details and permissions.
ian3d
Users browsing this forum: Google [Bot] and 29 guests
