Cannot connect externally
Postby wilzyk » Mon Jun 09, 2014 7:19 pm
Hi there,
I've had Subsonic working correctly for around a week now - today it decided to drop out. I can still access it perfectly from my home network, just externally that I can't. Port forwarding is all OK, the error message I'm getting is 'Status: wilzyk.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)'
I have not changed any settings etc since I got it to work - does anyone have any ideas what could be up with it? Thanks in advance!
wilzyk
Re: Cannot connect externally
Postby alphawave7 » Mon Jun 09, 2014 7:23 pm
Is your server lan IP static? Can you test your port on canyouseeme.org and pass the test?
Postby wilzyk » Mon Jun 09, 2014 7:40 pm
alphawave7 wrote:Is your server lan IP static? Can you test your port on canyouseeme.org and pass the test?
It's not - currently on DCHP. I'm with BT in the UK, can I/do I need a static IP? I have just checked and can not pass the test on canyouseeme - it passed fine when I set it up, is this because I do not have a static IP?
Sorry for the bombardment of questions (new to this!) and thanks for the response
wilzyk
Postby alphawave7 » Tue Jun 10, 2014 1:41 pm
Yes...server needs to be on a fixed lan address. I'd recommend a read of the Windows Setup Guide here in Tutorials. :)
Users browsing this forum: No registered users and 102 guests
