FreeNAS and DLNA problem
Postby ighab24 » Thu Jun 12, 2014 11:26 am
Having a go at using Subsonic as a media server using the Plugin in FreeNAS 9.2. All installed and started fine.
I can access the web page http://myNAS:4040/ and have been able to map my media so it is visible within the application. So all good so far.
However, I want to have DLNA enabled as I want to stream my music using Subsonic to my Marantz hifi and Sony tele using controller on Nexus phone. So... I can see that the DLNA option is enabled in the Settings > DLNA tab. and get this in the logs:
[2014-06-12 10:40:10,096] INFO UPnPService - Disabling UPnP/DLNA media server
[2014-06-12 11:48:40,508] INFO UPnPService - Enabling UPnP/DLNA media server
however it is not being presented as an option in Media Devices on the network "panel" of my Windows 7 machine or as an option on my Nexus.
I am using a BT Homehub and uPNP is enabled on that and my existing devices all present themselves on the network correctly. E.g. I have already tested the following other Media Players:
Synology ds212j
Plex, MiniDLNA, Serviio (all configured as plugin in jail in FreeNAS)
Wondering what I am missing here with Subsonic. Help please!? I have read about the port forwarding in my Router - but assume this is for internet access which I dont want to do at this time.
Sorry if missed something obvious but did do a search of forum first
Cheers,
ighab24
Re: FreeNAS and DLNA problem
Postby ighab24 » Thu Jun 12, 2014 12:14 pm
Just follow up and this may be complete rubbish but when I do a netstat command:
root@subsonic_1:/usr/pbi/subsonic-amd64/etc # netstat -an
Active Internet connections (including servers)
Proto Recv-Q Send-Q Local Address Foreign Address (state)
tcp4 0 0 192.168.1.4.4040 192.168.1.70.55316 ESTABLISHED
tcp4 0 0 192.168.1.4.4040 192.168.1.70.55234 ESTABLISHED
tcp4 0 0 192.168.1.4.4040 192.168.1.70.55233 ESTABLISHED
tcp4 0 0 192.168.1.4.4040 192.168.1.70.55232 ESTABLISHED
tcp46 0 0 *.19805 *.* LISTEN
tcp46 0 0 *.9412 *.* LISTEN
tcp46 0 0 *.4040 *.* LISTEN
tcp4 0 0 192.168.1.4.12347 *.* LISTEN
udp4 0 0 *.514 *.*
udp6 0 0 *.514 *.*
I dont see port 1400 open protocol udp (Which I thought was the upnp port). should it be?
Cheers,
ighab24
