simultaneous streams/direct links
Postby boomp » Sun Sep 24, 2006 11:08 pm
hi.. first of all, great software!
i just installed it, and am still figuring out how everything's working.. i read the faq's and forum, but still no solace.. sorry for the probably very stupid questions ;)
i'd like to use subsonic to manage streams for me.. my plan is to be able to run 4 stream simultaneously, with all 4 running different playlists..
i was under the impression that this is possible but atm i have no idea how to :)
also i'd like to just have a url like http://mydomain.bla/stream1.mp3 wich would lead to that stream, instead of people having to log on the subsonic web interface.. (wich is nice btw, but i'd like to keep the playlist management to myself :) )
is this possible?
thanks!
boomp
Postby sindre_mehus » Mon Sep 25, 2006 8:06 am
I suggest you try the following: Create your playlists, and save them as a.m3u, b.m3u, c.m3u (for instance).
Then you can open the following links in your player (e.g., WinAmp):
http://mydomain.bla/subsonic/stream?pla ... suffix=mp3
If you want to be able to start the streams directly from the browser, you must publish on your web server m3u files containing the links above. For instance, create a file "foo.m3u" with the following content:
#EXTM3U
#EXTINF:-1,Subsonic
http://mydomain.bla/subsonic/stream?playlist=a.m3u&suffix=mp3
Finally, create a link to foo.m3u from your ordinary web page.
Hope this helps,
Postby boomp » Mon Sep 25, 2006 11:30 am
wow. it's actually WORKING!
i've some more questions..
i see my playlist start at track one all the time.. i was kinda aiming on a radio-sortof thing.. is this possible as well? or at least a shuffle-mode?
also, i'd like to change the (subsonic) thing after the tracktitle..
another thing.. i was wondering if it's possible to stream stuff into icecast/shoutcast without too much trouble.. (i have a hunch it isn't but it just might be :)
thanks for helping out :)
boomp
Postby sindre_mehus » Mon Sep 25, 2006 11:39 am
Yeah, well, the "normal" way to use Subsonic is to let the end users log on to the system and select themselves what they want to play. But with the aforementioned tricks it should be possible to achieve what you want to do. Haven't tried it myself, though...
Postby boomp » Mon Sep 25, 2006 11:51 am
ah, you replied while i was editing my last post.. hehe..
boomp
Postby sindre_mehus » Mon Sep 25, 2006 12:53 pm
With this modus operandi, not starting at the beginning of the playlist is currently not possible, neither is shuffle mode.
To change the "(Subsonic)", edit the #EXTINF in your m3u.
If you want to do radio-like broadcasting, you're probably better off using a pure Icecast solution. (However, it might be possible to have your Icecast server reading data from Subsonic. I haven't tried Icecast so I can't tell if it's feasible.)
Cheers,
Postby boomp » Mon Sep 25, 2006 2:27 pm
hmm.. yes i figured something like that..
there doesn't seem to be any software that can broadcast multiple streams to a server.. and since i'm not planning on starting anything big i think running 4 boxes with a mediaplayer each is a bit overdone :)
oh well. this isn't too bad either..
boomp
Postby leolo » Fri Feb 09, 2007 6:51 pm
Hello.
And to open the playlist ramdomly?
I mean something like when you click it opens ramdomly a.m3u, b.m3u, or c.m3u.
Something like this is possible?
leolo
Users browsing this forum: No registered users and 70 guests
