Library Slider Not Working with DSub
Postby Tranquilfire » Sun Jun 29, 2014 8:35 pm
I have a huge library and I used to be able to scroll through using the slider on the right of the library. Now I can't for some reason. I don't know if it's something to do with my phone or with DSub itself. I've got a Galaxy S3 running Android 4.4.2 and DSub version 4.7.1. I thought maybe I was just fat-fingering it but I'm unable to grab the slider with my finger which makes scrolling through the library a painful process. Any suggestions?
Tranquilfire
Re: Library Slider Not Working with DSub
Postby GJ51 » Sun Jun 29, 2014 10:12 pm
+1
Yes, I've noticed the same thing on my Note 2
Makes scrolling through the library very tedious.
Probably due to recent update that should be an easy fix for the dev.
LOL - easy for me to say...
Postby daneren2005 » Sun Jun 29, 2014 10:26 pm
Before I had it hard coded to always be enabled because of a platform bug introduced in 4.4. They fixed it in 4.4.3, and I goofed and just removed the work around I forgot that there will probably still be phones on 4.4.2 and below forever. It should be a easy fix, I just need to add a check to only do the work around for 4.4 - 4.4.2 in the next version.
