Drag and Drop Tracks
Postby txmed » Sun Jul 06, 2014 12:03 am
TL;DR Does any client/app allow drag and drop functionality for tracks?
There has to be a better way to create playlists, or to reorder tracks in album or library view, that are required to be played in a certain order than what I've found in my brief experience with Subsonic.
My specific situation is I have a number of audiobooks which have previously been broken up into sometimes >100 individual tracks to meet the size limit to be uploaded to Google Play.
Now, new to Subsonic, in album view, even if the metadata is correct, they appear as something like:
1
10
11
12
13
14
2
20
21
22
The only way I can figure to create in order playlist is to add 1,2,3,4,5,6,7,8,9,10 then come back and do the same up to 100, etc. That's really tedious and painful for hundreds of books. What would be beautiful would be drag and drop ability for reordering tracks or adding tracks to playlists.
I'm running the most recent stable release of Subsonic on an Ubuntu TT server. I've tried the Subsonic web interface, Jamstash, Submariner (which doesn't seem to work at all), UltraSonic and DSub but none of them appear to have that feature (or I can't figure it out). This is gonna be hours of work on my part unless someone has something to help. Thanks in advance.
txmed
Re: Drag and Drop Tracks
Postby blueturtles » Sun Jul 06, 2014 3:33 am
Why not try renumbering the tracks. If on Windows try mp3tag software. Hope that helps.
blueturtles
Postby blueturtles » Sun Jul 06, 2014 3:46 am
What I meant is that you could at leading "zeroes" to the single numbers. I know that will mean re-uploading the tracks, but I with I had an easier way. Good luck.
blueturtles
Users browsing this forum: Google [Bot] and 40 guests
