nginx SSL proxy issues
Postby lloydwatkin » Thu Jul 10, 2014 11:03 am
Hi all,
I've previously had this set up ok, but can't seem to get working now. When I visit https://music.evilprofessor.co.uk then I get to subsonic but it immediately redirects to http at which can't it can't be loaded. I'm missing something in my configuration somewhere (and it will doubtless be simple)
Help appreciated!
nginx:
server {
       listen 443;
       ssl on;
       server_name     music.evilprofessor.co.uk;
       access_log      /var/log/nginx/subsonic.access.log;
       error_log       /var/log/nginx/subsonic.error.log;
       ssl_certificate      /etc/ssl/private/ssl.server.crt;
       ssl_certificate_key  /etc/ssl/private/ssl.server.key;
       ssl_protocols  SSLv2 SSLv3 TLSv1;
       ssl_ciphers  HIGH:!aNULL:!MD5;
       ssl_prefer_server_ciphers   on;
       location / {
                proxy_pass      http://127.0.0.1:4040;
                proxy_redirect  off;
                proxy_set_header        Host            $host;
                proxy_set_header        X-Real-IP       $remote_addr;
                proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
/etc/default/subsonic
# (/etc/init.d/subsonic)
# For example, to specify that Subsonic should use port 80 (for http)
# and 443 (for https), and use a Java memory heap size of 200 MB, use
# the following:
# SUBSONIC_ARGS="--port=80 --https-port=443 --max-memory=200"
SUBSONIC_ARGS="--max-memory=150 --https-port=0 --port=4040"
# The user which should run the Subsonic process. Default "root".
# Note that non-root users are by default not allowed to use ports
# below 1024. Also make sure to grant the user write permissions in
# the music directories, otherwise changing album art and tags will fail.
SUBSONIC_USER=subsonic
lloydwatkin
