Server error: NullPointerException
Postby enix » Sun Jul 13, 2014 1:02 am
Problem Description: When I try to load certin podcasts from the podcast tab on the Dsub app I get the error: 'Server error: NullPointerException'
Troubleshooting Steps: Most my podcast url's are from feedburner, some work, some dont. I have emailed the DSub developer and he confirmed it is not an error with his app. The official app has no Podcast tab to test. All my podcasts work via the web interface. I have looked at the logs, but to be honest I dont really know what I'm looking for.
Playback Application and version: DSub app, 4.7.1
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: Jetty-6.1.x, java 1.8.0_05, Linux (65.6 MB / 143.5 MB)
Hardware Platform: Linux hpbun 3.8.0-42-generic #63~precise1-Ubuntu SMP Fri Jul 4 21:16:26 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Java Memory Limit: no idea
Problem Filename: NA
Output from ffmpeg -i: Not sure if this part pertains to my issue, but here it is.
dingo@hpbun:~% ffmpeg -i storage/Podcast/The\ Adam\ Carolla\ Show/2013.11.21ACS.
mp3
ffmpeg version 0.8.12-4:0.8.12-0ubuntu0.12.04.1, Copyright (c) 2000-2014 the Lib
av developers
  built on Jun 10 2014 15:31:10 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future
release. Please use avconv instead.
[mp3 @ 0x2401820] Header missing
[mp3 @ 0x24007a0] max_analyze_duration reached
[mp3 @ 0x24007a0] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'storage/Podcast/The Adam Carolla Show/2013.11.21ACS.mp3':
  Metadata:
    title           : Adam, Alison, and Bald Bryan
    album           : Carolla Digital
    genre           : comedy
    artist          : The Adam Carolla Show
    TIME            : 2027
    date            : 2013
  Duration: 01:24:20.23, start: 0.000000, bitrate: 64 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, mono, s16, 64 kb/s
Last ten log file lines:
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) genre : Rock
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) date : 1995
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, s16, 1411 kb/s
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[7/12/14 5:56:48 PM CDT]    DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[7/12/14 5:56:48 PM CDT]    DEBUG   JukeboxService   Opened line com.sun.media.sound.DirectAudioDevice$DirectSDL@40491f79
[7/12/14 5:56:48 PM CDT]    INFO   JukeboxService   miche starting jukebox for "(What's the Story) Morning Glory_/12 Champagne Supernova.mp3"
[7/12/14 6:25:14 PM CDT]    INFO   RESTRequestParameterProcessingFilter   Authentication failed for user
[7/12/14 6:25:56 PM CDT]    WARN   RESTFilter   Error in REST API: NullPointerException
[7/12/14 7:38:18 PM CDT]    WARN   RESTFilter   Error in REST API: NullPointerException
[7/12/14 7:38:21 PM CDT]    WARN   RESTFilter   Error in REST API: NullPointerException
[7/12/14 7:43:36 PM CDT]    WARN   RESTFilter   Error in REST API: NullPointerException
[7/12/14 7:43:37 PM CDT]    WARN   RESTFilter   Error in REST API: NullPointerException
Let me know if anything more is needed.
Please be gentle, I don't know much, just barely enough to get going.
Thanks in advance for any advice.
enix
Re: Server error: NullPointerException
Postby sindre_mehus » Thu Aug 14, 2014 8:38 pm
The log file (/var/subsonic/subsonic.log) contains more details about the NullPointerException. Can you please post it?
Postby enix » Fri Aug 15, 2014 2:14 am
http://paste.ubuntu.com/8050015/
Thanks for looking. I appreciate it.
enix
Postby enix » Thu Oct 02, 2014 3:53 pm
FYI, I am still having issues and monitoring this thread. Any help/ideas would be much appreciated.
Thanks.
enix
