Will no longer stream to android devices after beta upgrade
Postby sdamaged99 » Thu Jul 17, 2014 9:32 am
I upgraded to subsonic 5.0 beta 1, and now music won’t stream to any android devices. It starts the download then just stops, and the music won’t play
This is using wifi or data. Subsonic log doesn’t seem to show any errors either.
Problem Description: App will see library but when you start a song, it appears to download then just stops. No track will play on either wifi or data
Troubleshooting Steps: Restarted server, tested different mobile phones and user accounts
Playback Application and version: Latest Subsonic android App on Galaxy Note 3/S4
Subsonic Version: 5.0.beta1 (build 4046) – May 24, 2014
Server Version: jetty-6.1.x, java 1.7.0_21, Windows Server 2012 (52.8 MB / 100.2 MB)
Hardware Platform: Windows Server 2012
Java Memory Limit: 64MB of 1024MB
Output from ffmpeg -i: N/A
Last ten log file lines:
[7/17/14 7:23:30 PM BST] INFO PlayerDao Created player 55.
[7/17/14 7:23:30 PM BST] INFO VersionService Resolved latest Subsonic final version to: 4.9
[7/17/14 7:23:30 PM BST] INFO VersionService Resolved latest Subsonic beta version to: 5.0.beta1
[7/17/14 7:29:52 PM BST] INFO PlayQueueInputStream barry listening to "A Fine Day to Exit\01 Pressure.flac"
[7/17/14 7:29:52 PM BST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [d:\FLAC\Anathema\A Fine Day to Exit\01 Pressure.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[7/17/14 7:30:26 PM BST] WARN RESTFilter Error in REST API: EofException
[7/17/14 7:30:26 PM BST] ERROR JAXBWriter Failed to marshal JAXB
[7/17/14 7:30:26 PM BST] ERROR RESTFilter Failed to write error response.
[7/17/14 7:30:27 PM BST] INFO PlayQueueInputStream barry listening to "Dirt\12 Down In A Hole.flac"
[7/17/14 7:30:27 PM BST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [d:\FLAC\Alice In Chains\Dirt\12 Down In A Hole.flac] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
sdamaged99
Re: Will no longer stream to android devices after beta upgr
Postby sdamaged99 » Thu Jul 17, 2014 6:57 pm
OK, i've managed to fix it by amending my transcoding settings.
This has annoyed me as i did not do anything except install the newer version of Subsonic, so i don't know how this suddenly broke my FLAC to MP3
New transcoding settings :
ffmpeg -i %s -ab 224k -id3v2_version 3 -map_metadata 0 -map 0:0 -ar 44100 -ac 2 -v 0 -f mp3 -
Previous setting (default!!)-
ffmpeg -i %s -ab %bk -v 0 -f mp3 -
Anyone know what on earth happened?
sdamaged99
Nope, not working again
Also it's now rebooting both my Note 3 and my wife's Galaxy S4..
Might do a complete reinstall and bin off this dodgy beta build
sdamaged99
Postby chugmonkey » Fri Jul 18, 2014 3:31 pm
I was having problems that were resolved by adding -map 0:0 to the transcode directive. However, I also added it to my downsample command. That has worked now across all my tracks, flac or otherwise, embedded cover or not.
Hope this helps someone.
chugmonkey
Postby Mauriac » Sat Jul 19, 2014 6:38 am
I can confirm the problem - audio music playing does not work after beta update.
I can also confirm chugmonkey's fix - audio playback is restored after adding the paramater above to the transcode directive in the Subsonic web interface.
Mauriac
