Error 503 service_unavailable
Postby kcay2 » Thu Jul 24, 2014 4:26 pm
After trying to upgrade to java 1.8, not having it working, then downgrading back to java 1.6, I am faced with the dreaded 503 ERROR each time I try to load subsonic.
I am running subsonic 4.9 on a raspberry pi. The initial install worked, but then after I upgraded to java 1.8 then downgraded to 1.6, I am faced with this problem.
The webpage error in full is:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
and here is my log file.
421 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@23af64: display name [org.springframework.context.support.ClassPathXmlApp$
[GC 2047K->373K(6912K), 0.0490500 secs]
1428 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
[GC 2420K->481K(6912K), 0.0583820 secs]
[GC 2529K->542K(6912K), 0.0289070 secs]
[GC 2590K->642K(6912K), 0.0150630 secs]
[GC 2689K->1073K(6912K), 0.0307960 secs]
8303 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@23af64]: org.springframework.beans.factory.su$
8540 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1b95de0: defining beans [service,org.springfram$
8961 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
[GC 3121K->1132K(6912K), 0.0313560 secs]
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/3853
9652 [main] INFO org.mortbay.log - jetty-6.1.x
[GC 3180K->1365K(6912K), 0.0352840 secs]
11471 [main] WARN org.mortbay.log - Could not instantiate listener net.sf.ehcache.constructs.web.ShutdownListener
java.lang.ClassNotFoundException: net.sf.ehcache.constructs.web.ShutdownListener
        at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:375)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
        at org.mortbay.jetty.handler.ContextHandler.loadClass(ContextHandler.java:1003)
        at org.mortbay.jetty.webapp.WebXmlConfiguration.initListener(WebXmlConfiguration.java:629)
        at org.mortbay.jetty.webapp.WebXmlConfiguration.initWebXmlElement(WebXmlConfiguration.java:367)
        at org.mortbay.jetty.webapp.WebXmlConfiguration.initialize(WebXmlConfiguration.java:289)
        at org.mortbay.jetty.webapp.WebXmlConfiguration.configure(WebXmlConfiguration.java:222)
        at org.mortbay.jetty.webapp.WebXmlConfiguration.configureWebApp(WebXmlConfiguration.java:180)
        at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1215)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:534)
11661 [main] WARN org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@1852afc{/,jar:file:/usr/share/subsonic/subsonic.war!/}
java.util.zip.ZipException: error in opening zip file
        at java.util.zip.ZipFile.open(Native Method)
        at java.util.zip.ZipFile.<init>(ZipFile.java:132)
        at java.util.jar.JarFile.<init>(JarFile.java:153)
        at java.util.jar.JarFile.<init>(JarFile.java:117)
        at org.mortbay.jetty.webapp.TagLibConfiguration.configureWebApp(TagLibConfiguration.java:171)
12154 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
13203 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
13936 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
[GC 3413K->1655K(6912K), 0.0527590 secs]
14629 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
Can anyone help?
kcay2
Re: Error 503 service_unavailable
Postby GJ51 » Thu Jul 24, 2014 7:18 pm
This is due to corrupting the db files that happens when you do something disruptive without first stopping the Subsonic service. Abrupt shutdowns, upgrades, reconfigurations that are unexpected when the Subsonic service is active doesn't let the database files get closed properly before the changes disrupt the application service.
ALWAYS - Make regular backups of the data directory (C:\Subsonic on Windoze or var/subsonic on Lumux)
If you don't have a backup, you can search the forums for recommended alternatives, but this sort of thing usually result in a complete re - installation as the least painful approach if you don't have a copy of the data directory.
HTH
Postby kcay2 » Fri Jul 25, 2014 5:30 am
Deleting var/subsonic then reinstalling fixed it -- and now it works with java 1.8. Thanks!
kcay2
Users browsing this forum: Google [Bot] and 40 guests
