Cover art exists, but does not display
Postby gopherdb » Sat Aug 02, 2014 5:33 pm
I have an issue with just a couple of albums where the cover art is present as cover.jpg in the album folder, is recognized by subsonic, but is not visible while viewing the library. The issue is better understood by viewing this screenshot:
http://i.imgur.com/yoEZLCo.png
In the screenshot you can see that when you click on the blank album art, it is viewable in the preview.
Since this only happens on a couple of albums out of hundreds, could the issue be related to the files and not subsonic? I have checked file and share permissions on the albums in question as well as making sure they are not read-only. I have tried different images for the cover, restarted subsonic and computer, cleaned library and rescanned.
gopherdb
Re: Cover art exists, but does not display
Postby idic314 » Thu Sep 11, 2014 1:22 am
Same problem here. Any solution to this?
idic314
Re: AW: Cover art exists, but does not display
Postby MadEvil » Thu Sep 11, 2014 4:16 pm
Maybe its a browser cache problem, try to clean up cache and from the context menu 'reload/refresh frame'.
Best regards
Madsonic Developer
MadEvil
