Very high repsonse times
Postby m1dnight » Tue Aug 05, 2014 10:44 am
I've been using Subsonic for a few years now. However, since the last versions I've noticed that Subsonic shows very high response times from time to time (+ 2 seconds). The same goes for when I connect through my android phone using the application. The problem is also present over LAN.
I have started using HTTPS recently though. Could this be a cause?
--> Edit, I've switched back to regular HTTP and the probleem seems to be gone.
Is there something that can be done about this? :)
Playback Application and version: (The end application that you are using to stream from Subsonic)
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.7.0_65, Windows Server 2012 (73.1 MB / 225.7 MB)
Hardware Platform: Windows Server 2012 on Core i5 /16 GB RAM
Java Memory Limit: 512 MB
Last ten log file lines:
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) built on Jul 28 2011 01:57:12 with gcc 4.6.1
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libavutil 51. 11. 0 / 51. 11. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libavcodec 53. 9. 0 / 53. 9. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libavfilter 2. 27. 3 / 2. 27. 3
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) [flac @ 003C9EC0] max_analyze_duration 5000000 reached at 5015510
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Input #0, flac, from 'H:\music\Rock\The Beatles\Core Studio MFSL\1965 - Rubber Soul\Beatles, The - Rubber Soul (MFSL Ebbetts) - 11. In My Life.flac':
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Metadata:
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) GENRE : Rock
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TITLE : In My Life
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) ALBUM : Rubber Soul (MFSL Ebbetts)
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) ARTIST : Beatles, The
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) DATE : 1965
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) track : 11/14
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Duration: 00:02:27.16, bitrate: 837 kb/s
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, stereo, s16
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Output #0, mp3, to 'pipe:':
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TCON : Rock
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TIT2 : In My Life
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TALB : Rubber Soul (MFSL Ebbetts)
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TPE1 : Beatles, The
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TDRL : 1965
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TRCK : 11/14
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) TSSE : Lavf53.6.0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: libmp3lame, 44100 Hz, stereo, s16, 128 kb/s
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Stream mapping:
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Stream #0.0 -> #0.0
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) Press [q] to stop, [?] for help
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) size= 2300kB time=00:02:27.20 bitrate= 128.0kbits/s
[8/5/14 12:36:02 PM CEST]   DEBUG   InputStreamReaderThread   (c:\subsonic\transcode\ffmpeg) video:0kB audio:2300kB global headers:0kB muxing overhead 0.012441%
[8/5/14 12:36:02 PM CEST]   DEBUG   AudioScrobblerService   Successfully registered submission for song 'In My Life' for user m1dnight at Last.fm: Tue Aug 05 12:36:02 CEST 2014
[8/5/14 12:38:20 PM CEST]   INFO   PlayQueueInputStream   admin listening to "2012 - Arche\01 gold.mp3"
m1dnight
