MP4 is not being transcoded correctly/won't play
Postby GH0 » Sun Aug 10, 2014 3:18 pm
Problem Description:
MP4's either do not play, or won't transcode. Both ffmpeg and lame are installed, and while I can play some MP4s, the majority of them do not transcode properly or play in subsonic (or any other subsonic music player like the android client or dsub).
The original songs play fine if I load them in Foobar2000.
Playback Version:
Dsub 4.7.3
Subsonic Web Player 5.0 Beta 1
Subsonic Version
I have Subsonic 5.0.beta1 (build 4048)
Server Version:
jetty-6.1.x, java 1.7.0_55, Linux (96.4 MB / 128.0 MB)
The log file for one of the affected song is as follows:
[8/10/14 9:46:29 AM CDT]    INFO   PlayQueueInputStream   GH0 listening to "Tove Lo - Out of Mind/01 Out of Mind 1.m4a"
[8/10/14 9:46:29 AM CDT]    DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/stor/music/Music/Tove Lo/Tove Lo - Out of Mind/01 Out of Mind 1.m4a] [-ab] [128k] [-v] [0] [-f] [mp3] [-]
[8/10/14 9:46:29 AM CDT]    DEBUG   AudioScrobblerService   Successfully registered now playing for song 'Out of Mind' for user volumus at Last.fm: Sun Aug 10 09:46:29 CDT 2014
[8/10/14 9:46:41 AM CDT]    INFO   PlayQueueInputStream   GH0 listening to "Sinjin Hawke x Just Blaze - One [WEB][320]/01 One.mp3"
Hardware Platform: Linux - Ubuntu 14.04
Output from ffmpeg -i:
@server:~$ sudo /var/subsonic/transcode/ffmpeg -i /media/stor/music/Music/Tove\ Lo/Tove\ Lo\ -\ Out\ of\ Mind/01\ Out\ of\ Mind\ 1.m4a
ffmpeg version N-61445-gdded5ed Copyright (c) 2000-2014 the FFmpeg developers
  built on Mar 14 2014 05:12:40 with gcc 4.6 (Debian 4.6.3-1)
  configuration: --prefix=/root/ffmpeg-static/32bit --arch=x86_32 --extra-cflags='-m32 -I/root/ffmpeg-static/32bit/include -static' --extra-ldflags='-m32 -L/root/ffmpeg-static/32bit/lib -static' --extra-libs='-lxml2 -lexpat -lfreetype' --enable-static --disable-shared --disable-ffserver --disable-doc --enable-bzlib --enable-zlib --enable-postproc --enable-runtime-cpudetect --enable-libx264 --enable-gpl --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-version3 --enable-libvpx
  libavutil      52. 66.101 / 52. 66.101
  libavcodec     55. 52.102 / 55. 52.102
  libavformat    55. 34.101 / 55. 34.101
  libavdevice    55. 11.100 / 55. 11.100
  libavfilter     4.  3.100 /  4.  3.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 18.100 /  0. 18.100
  libpostproc    52.  3.100 / 52.  3.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0xa971440] stream 0, timescale not set
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/media/stor/music/Music/Tove Lo/Tove Lo - Out of Mind/01 Out of Mind 1.m4a':
  Metadata:
    major_brand     : M4A
    minor_version   : 0
    compatible_brands: M4A mp42isom
    creation_time   : 2009-06-10 09:20:14
    title           : Out of Mind
    artist          : Tove Lo
    album_artist    : Tove Lo
    album           : Out of Mind - Single
    genre           : Pop
    track           : 1/1
    disc            : 1/1
    gapless_playback: 0
    date            : 2013-10-16T07:00:00Z
    copyright       : ℗ 2013 Universal Music AB
    media_type      : 1
  Duration: 00:03:06.60, start: 0.000000, bitrate: 290 kb/s
    Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 265 kb/s (default)
    Metadata:
    Stream #0:1: Video: mjpeg, yuvj444p(pc), 600x600 [SAR 72:72 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
GH0
Users browsing this forum: Bing [Bot] and 18 guests
