import multiple playlists
Postby postjosh » Tue Aug 12, 2014 4:23 pm
hi. i'm importing my playlists which works fine. howerver, i have over 500 playlists so this is a huge pita! is there a way to import multiple playlists? thanks.
postjosh
Re: import multiple playlists
Postby postjosh » Sun Aug 17, 2014 12:54 am
ok... nevermind.i found the import playlist folder setting under the general settings.
postjosh
Postby postjosh » Tue Aug 19, 2014 12:57 pm
but it doesn't work for me. :(
4.9 (build 3819) – January 23, 2014 jetty-6.1.x, java 1.6.0_65, Mac OS X (102.1 MB / 136.6 MB)
postjosh
