Change Subsonic Default User
Postby MR. Pockets » Tue Aug 19, 2014 4:03 pm
I have just installed Subsonic on Ubuntu Server 14.04 but am having trouble changing the default user so Subsonic is not running as root.
When I opened /etc/default/subsonic there was no "DEFAULT_USER=" string, so I tried adding it and setting it to "subsonic" (I have added that user). I then restarted the subsonic service. However, when I log into the web interface to set things up, I am still receiving the warning that Subsonic is running as root. How do I change the user?
If it makes a difference, I followed this guide to install - http://www.bestubuntu.com/subsonic-musi ... 12-04.html
Subsonic Version:
4.9 (build 3819) – January 23, 2014
Server:
jetty-6.1.x, java 1.7.0_55, Linux (34.1 MB / 48.7 MB)
Platform:
Ubuntu Server 14.04
Log file:
[8/19/14 9:43:49 AM MDT] INFO DaoHelper Checking database schema.
[8/19/14 9:43:50 AM MDT] INFO DaoHelper Done checking database schema.
[8/19/14 9:43:50 AM MDT] INFO PlayerDao Deleted 1 player(s) that haven't been used after Fri Jun 20 09:43:50 MDT 2014
[8/19/14 9:43:51 AM MDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Aug 20 03:00:00 MDT 2014
[8/19/14 9:43:51 AM MDT] INFO UPnPService Starting UPnP service...
[8/19/14 9:43:51 AM MDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Aug 19 09:48:51 MDT 2014
[8/19/14 9:43:51 AM MDT] INFO VersionService Resolved local Subsonic version to: 4.9
[8/19/14 9:43:52 AM MDT] INFO UPnPService Enabling UPnP/DLNA media server
[8/19/14 9:43:52 AM MDT] INFO UPnPService Starting UPnP service - Done!
[8/19/14 9:44:01 AM MDT] INFO NetworkService Deleted port mapping for port 4040
[8/19/14 9:44:02 AM MDT] INFO PlayerDao Created player 1.
[8/19/14 9:44:04 AM MDT] INFO VersionService Resolved latest Subsonic final version to: 4.9
[8/19/14 9:44:04 AM MDT] INFO VersionService Resolved latest Subsonic beta version to: 5.0.beta1
[8/19/14 9:48:51 AM MDT] INFO PodcastService Starting scheduled Podcast refresh.
[8/19/14 9:48:51 AM MDT] INFO PodcastService Completed scheduled Podcast refresh.
MR. Pockets
Re: Change Subsonic Default User
Postby daneren2005 » Tue Aug 19, 2014 4:38 pm
DEFAULT_USER is not a parameter. You need to use something like:
SUBSONIC_USER=www-data
It should be at the bottom of the /etc/default/subsonic file
Postby MR. Pockets » Tue Aug 19, 2014 5:34 pm
Thank you for your quick reply. I deleted
DEFAULT_USER=subsonic
added
SUBSONIC_USER=subsonic
and restarted the subsonic service but I'm still getting the warning.
When I first opened it, the file did not have any parameters in it other than
SUBSONIC_ARGS="--max-memory=100"
The current contents of /etc/default/subsonic are
# (/etc/init.d/subsonic)
# For example, to specify that Subsonic should use port 80 (for http)
# and 443 (for https), and use a Java memory heap size of 120 MB, use
# the following:
# SUBSONIC_ARGS="--port=80 --https-port=443 --max-memory=120"
MR. Pockets
Users browsing this forum: No registered users and 44 guests
